3rd gear grind at higher rpm - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-16-2013, 12:46 AM Thread Starter
Hi,
I am looking at this nice 06 gto with the t56 6 speed trans. There is a grind when shifting into 3rd at medium to high rpms. Every other gear is fine.
Is this a common problem?
from my experience with manual transmissions the most likely cause of gear grinding would be the syncro's but I have never owned a gto or any gm vehicle.
If a rebuild would be required, can anyone ballpark a $$ amount? I am in NYC area.
cummlns is offline
post #2 of 4 (permalink) Old 10-16-2013, 06:14 PM
The stock clutch can do the same thing of not disengaging fully at high RPM
post #3 of 4 (permalink) Old 10-16-2013, 06:29 PM Thread Starter
The stock clutch was replaced with a z06 clutch.
cummlns is offline
post #4 of 4 (permalink) Old 10-16-2013, 07:53 PM
But I'll bet is wasn't checked for shimming. Most mechanics assume it's "stock" for that drive-train so they just bolt up and go. The tolerances of the hydraulics are pretty critical.
Park your car on a flat surface and while in gear with the brakes off rev the engine and see if you move. If you even feel it a little the clutch is dragging and possibly needs the slave shimmed. There is a procedure for measuring.
3rd gear notchy mike4387 Drive train, suspension, alignment and brakes. 2 09-09-2011 06:23 PM
3rd gear issues Thepgavin 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-22-2011 10:10 PM
3rd Gear? taylorb765 Drive train, suspension, alignment and brakes. 5 06-26-2010 12:57 AM
Trouble getting into 3rd gear Bandit 2004-2006 GTO General Discussion 3 02-26-2007 09:49 PM
2nd Gear Grind RipTheSix 2004-2006 GTO General Discussion 2 10-03-2006 10:15 AM
