A/4 Gto Trans Temp - Pontiac GTO Forum
post #1 of 6 (permalink) Old 12-15-2008, 05:36 AM Thread Starter
LOWET's Avatar
A/4 Gto Trans Temp
Does anyone have a trans fluid temp gauge on their 04-06 GTOs with A/4 trans. I am curious as to what your temps are reading during normal driving.
THANKS
447 CI forged stroker [ 7.3 liter ] 6 Bolt main caps
Holley Modular Mid rise Intake Manifold.
F1 Procharger ,
Just way too much to list,
LOWET is offline
post #2 of 6 (permalink) Old 12-18-2008, 04:46 AM
mark039's Avatar
My 04 usually runs between 175-185 degrees. Stock stall w/shiftkit.
Barbados blue 04 A4...HSW dry plate kit(100shot),NGK TR6's, ds predator, jba shorties, jba o/r mids, jba wires, transgo shift kit, K&N cai, lpe 160 stat, EE catch can, flowmaster cb, tb bypass, noltec diff insert
mark039 is offline
post #3 of 6 (permalink) Old 12-18-2008, 01:15 PM Thread Starter
LOWET's Avatar
Thanks. I guess mine is OK. I have a 3600 RPM stall with a B&M cooler. It runs around 180 degrees
F1 Procharger ,
LOWET is offline
post #4 of 6 (permalink) Old 12-18-2008, 03:26 PM
GM4life's Avatar
Thats good that you have a B&M cooler, number one killer of an auto is overheating the fluid.
GM4life is offline
post #5 of 6 (permalink) Old 12-19-2008, 07:21 AM
I was told at a service class that every 10* you reduce the tranny temp, you double the life of the tranny.
post #6 of 6 (permalink) Old 12-19-2008, 01:43 PM Thread Starter
LOWET's Avatar
I have been thinking about swaping out the stock fluid pan for one with a larger capacity and cooling fins
F1 Procharger ,
LOWET is offline
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Install Trans Temp Gauge on 05? macdogg Service, Maintenance and Technical Discussion 0 10-27-2005 09:51 AM
June 2005 GTO Incentives?? saabdue 2004-2006 GTO General Discussion 8 05-26-2005 11:30 PM
UK's Top Gear reviews the GTO. 1COOLPC 2004-2006 GTO General Discussion 4 08-10-2004 06:18 PM
