5 beeps - Pontiac GTO Forum
post #1 of 7 (permalink) Old 02-09-2017, 04:00 PM Thread Starter
Quoted: 6 Post(s)
5 beeps
Is there anyway to turn off the 5 beep feature when the solenoid sticks? Also does anyone know if the 05 solenoid the same at the 04.
johnfin is offline
post #2 of 7 (permalink) Old 02-09-2017, 04:46 PM
GTO44's Avatar
Quoted: 37 Post(s)
Still having this issue 4 years later? lol
https://www.gtoforum.com/f3/remote-beeps-48841/
Did you ever checkout/fix the lock actuator's?
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #3 of 7 (permalink) Old 02-09-2017, 05:48 PM Thread Starter
Quoted: 6 Post(s)
Cant remember which gto that was. Real question is the solenoids the same for all years. I have a 05 parts car.
johnfin is offline
post #4 of 7 (permalink) Old 02-09-2017, 05:55 PM
HP11's Avatar
Quoted: 24 Post(s)
I'm thinking he hasn't because he's talking about a sticking solenoid (actuator). I had this issue about 8 years ago and replaced the passenger side actuator. Haven't had that problem since. From that experience I know that there is not a way to disable the 5 beep thing since that's a malfunction indication rather than a door lock indication. As far as I know the actuators are the same for all models.
HP11 is offline
post #5 of 7 (permalink) Old 02-10-2017, 10:42 AM Thread Starter
Quoted: 6 Post(s)
Wonder if the linkage are at fault more then the solenoid, ie lube and binding from lack of use. interesting point, how does the system know its bad even if the plunger is pushed down? Maybe the sensor that detects that is bad.
johnfin is offline
post #6 of 7 (permalink) Old 02-11-2017, 07:00 AM
HP11's Avatar
Quoted: 24 Post(s)
The linkage could be at fault but in my case it wasn't because that was the first thing I tried.
HP11 is offline
post #7 of 7 (permalink) Old 02-12-2017, 01:52 PM Thread Starter
Quoted: 6 Post(s)
parts
When you have 2 GTO's you also have a parts car. Replacement seems to be working. I use to have a hobbies, r/c planes and car, now I have GTO's
ID:	86842   Click image for larger version
ID:	86850   Click image for larger version
ID:	86858   Click image for larger version
johnfin is offline
Remote beeps johnfin Service, Maintenance and Technical Discussion 5 07-12-2014 04:12 PM
Mystery Beeps AGR81 2004-2006 GTO General Discussion 22 09-22-2005 09:05 AM
