60A main fuse desperate for help - Pontiac GTO Forum
post #1 of 2 (permalink) Old 04-22-2013, 12:14 PM Thread Starter
so about a week ago my car wouldnt start checked the fuses the main was blown. Put in a new one upon turning key to crank blew it again. any ideas of what wires to look at and in what areas to look at. my car has been down for a week just because i havent had time to look at it
LS6wantabe is offline
post #2 of 2 (permalink) Old 04-23-2013, 09:15 AM
60A is a lot of current but seeing you said it blew when you went to crank I'd suspect the starter. Have it checked out or disconnect the main power down by the starter and try to see if it still blows the fuse when you turn the key. If it doesn't then I'd say a shorted starter.
In desperate need of help RedCarnage Service, Maintenance and Technical Discussion 0 01-24-2012 02:39 PM
Routine Main't KyleGT05usmc Service, Maintenance and Technical Discussion 4 03-01-2009 09:45 AM
which fuse spice06 Service, Maintenance and Technical Discussion 0 05-08-2007 07:24 PM
2004 GTO in Desperate Housewives b_a_betterperson The Lounge 6 05-23-2005 08:09 PM
TV's "Desperate Housewives" & GTO Groucho 2004-2006 GTO General Discussion 6 10-25-2004 09:06 PM
