70 GTO Gauges. HELP!!!!! - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-29-2017, 07:34 PM Thread Starter
I have a 70 GTO with rally gauges. To make this story short I will not go through all the problems I have had and get to the main problem. I had the gauges out of the
pod and soaked it in vinegar to de-rust it. The gas gauge was bad and I had it rebuilt. The temp gauge worked fine but after putting it all back together the temp gauge pins to HOT as soon as I turn on the key. I have a brand new printed circuit also. Does anyone have a picture of the back of the gauges with the printed circuit off? There are four terminals in the temp gauge and there is an insulator going under three of them. I don't know if I have it on the correct three. PLEASE HELP! I'm going crazy with issues with this dash.
goatoligst is offline
post #2 of 3 (permalink) Old 07-30-2017, 12:12 PM
Have not personally encountered the pegging hot situation, but sure sounds like an incorrect sending unit problem. Have several sets of original '69-early 70 rally gauges boxed up, will be over tomorrow moving parts. Will try and pull the boxes out, they are in boxes & tubs yet to be moved.
post #3 of 3 (permalink) Old 07-30-2017, 01:25 PM Thread Starter
It can't be the sending unit. The gauge worked until I took it out and reinstalled it. I didn't touch anything under the hood. I have a feeling I have the insulator in the wrong position. The temp gauge is the only gauge with one. Any help would be appreciated.
Rally Cluster gauges for '67 GTO Goat67 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 19 05-14-2017 11:13 AM
Tach and gauges for 64 GTO tguggino 1964-1974 Tempest, Lemans & GTO General Discussion 6 01-14-2016 08:25 PM
1969 GTO gauges 69GTOCONVLOVER 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 10 12-26-2013 08:29 AM
non rally gauges in 70 gto even steven 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 06-28-2009 07:38 PM
