abs fault traction control shutting off - Pontiac GTO Forum
post #1 of 5 (permalink) Old 01-22-2014, 03:22 PM Thread Starter
Hey I just got my 2005 Gto and everthing seems to check out OK except for my "abs fault traction control off" pops up randomly. Its not every time I turn the car on, and will either come up right away or after driving for a little while. I do notice any thing happening so any thoughts? Maybe rear sensor or something? New to this platform anything helps thanks.
All stock no mods
cplanchard is offline
post #2 of 5 (permalink) Old 01-22-2014, 05:45 PM Thread Starter
Also I read the other thread about this, but the car had other variables to consider being that his was modified.
post #3 of 5 (permalink) Old 06-11-2014, 01:05 AM
Its a very simple system. Its not a stability control. The traction controls relies only on info from the wheel speed sensors. If one of them is faulty you loose both TC and ABS. In your case you lose both at the same time so i am pretty sure its a sensor.
Qnko is offline
post #4 of 5 (permalink) Old 06-11-2014, 06:05 PM
It could also be the MAF cable connection. You could try popping the plug off it it to inspect the connectors and firmly replug it back together. Loss of the MAF signal can cause that
post #5 of 5 (permalink) Old 03-18-2015, 08:09 PM
Why would that affect it? My maf sensor throw a code after changing to headers and now my traction control is shut off as well????
logan4720 is offline
ABS and TCS fault and off, help! F4LL3NBURR1T0 Service, Maintenance and Technical Discussion 3 09-05-2012 02:01 PM
2005 Throwing up code P0604 (Control Module RAM fault) rezarxt Service, Maintenance and Technical Discussion 6 08-04-2012 10:23 PM
ABS fault at 145 mph!!! banshee 2004-2006 GTO General Discussion 8 11-05-2008 04:44 PM
Traction control, still no traction :-) tummen 2004-2006 GTO General Discussion 14 08-22-2008 12:25 PM
ABS Fault muohio Service, Maintenance and Technical Discussion 5 05-07-2007 11:32 PM
