ABS and TCS fault and off, help! - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-01-2012, 10:52 AM Thread Starter
Ok so I have had my goat for a couple months now and I just finished having my Hendrix 8.8 kit adjusted for back lash, drove fine for a week or two. But then it went under the knife for a tick complete clutch package with a level 3 monster clutch with the MC slave etc. I finally got home to my car and now when I turn the key to on it throw abs fault and tcs is off and wonít come on. It stays this way while running also but still drives normally. Help?
F4LL3NBURR1T0 is offline
post #2 of 4 (permalink) Old 09-01-2012, 02:37 PM
danfigg's Avatar
re
Obviously it has to do with the ABS/traction control sensor on the rear. Something may not be compatable. I always wonder that when I think about putting a straight axle or 8.8 kit in my GTO and if it would be compatable with the ABS/traction control. The sensor is on the rear for the traction control and the brake caliper for the ABS.....OR you have the common BCM wiring problem which is the wires rub against a metal bracket in the glove box and ground out some wires. I know this isnt much help but I would make calls and find out Hendrix about the ABS traction control issue and it compatabilities and the wiring in the glove box. Also tire size would make a difference. You do have the same size tires in the front and back. That will throw the ABS traction controls off---danfigg
05 IBM M6 summit UDP Vararam OVRAI Dyno tech long tubes W 04/catted mids 04 spintech X-pipe merged into 05 kooks after burners In-tune diablo tuner
danfigg is offline
post #3 of 4 (permalink) Old 09-02-2012, 09:41 PM
At least on my '04 I'v been running with an inch smaller diameter tire in the front and it hasn't set off ABS. It must have to be pretty significant. Sounds like a rear sensor issue to me too.
post #4 of 4 (permalink) Old 09-05-2012, 02:01 PM
jpalamar's Avatar
I agree with Svede. My C5 fron tire is supposed to be smaller then my fronts. If not it will throw some crazy active handling/abs issues. I don't recall anyone having issues like that in the GTOs. In fact a few have put Vette wheels on without issue. Def has to be a specific sensor in the rear.
04 GTO - sold
jpalamar is offline
Fault code The intimidator Service, Maintenance and Technical Discussion 1 11-23-2010 07:27 AM
Air bag FAULT GoatOnMeth Service, Maintenance and Technical Discussion 3 05-13-2009 09:47 PM
ABS fault at 145 mph!!! banshee 2004-2006 GTO General Discussion 8 11-05-2008 04:44 PM
ABS Fault muohio Service, Maintenance and Technical Discussion 5 05-07-2007 11:32 PM
AirBag Fault DJ_YellowGTO Service, Maintenance and Technical Discussion 1 02-02-2005 08:45 AM
