AC on does it lessen power on 05 gto? and question about rubber driveshaft coupler... - Pontiac GTO Forum
post #1 of 5 (permalink) Old 07-31-2010, 09:29 PM Thread Starter
I have a 05 A4 yellow gto and today with the ac on driving around the city seems like it didnt have a responsive getty up power is this normal even on our goats like other cars where the ac puts a noticeable drag on the engine?
Or could it be that i just found out it needs a new front rubber drive shaft coupler also called flex rubber disc. its not shredded but it has cracks all the way around. the rear one close to the diff looks good.
I have a gm certified 1 year warranty n taking it to dealer next week sometime are those rubber discs replaceble or does the dealer need to replace the whole drive unit with all those rubber couplers?
Also i hear a loose clunking in the drive line somewhere im not sure if that bad front rubber coupler is cause so much play at low speeds when acclerating n decelerating from braking n gassing it. It kind of seems like the play n noise is at the diff area, maybe it needs a diff or those side axle geras are messed up huh? thanks
pctek is offline
post #2 of 5 (permalink) Old 07-31-2010, 11:22 PM
740tank's Avatar
yeah the rubber couplers are horrible that was a piss poor design
740tank is offline
post #3 of 5 (permalink) Old 08-01-2010, 01:07 AM
Bluegoat05's Avatar
Yes the ac does make a noticable difference when you floor it it is harder to tell but when you are just cruisin only light throttle changes I notice a difference
straight piped cat back, JBA shortys, JBA wires, AEM ca, and 421 slp tune
Bluegoat05 is offline
post #4 of 5 (permalink) Old 08-01-2010, 02:39 AM
AlaGreyGoat's Avatar
I believe the ECU turns off the A/C compressor at WOT.
As far as the rubber couplers, some dealers claim you
have to buy a complete driveshaft to get them, but a dealer
I called had them separate for about $220 ea.
Larry
AlaGreyGoat is online now
post #5 of 5 (permalink) Old 08-01-2010, 11:36 AM
RJ_05GTO's Avatar
The a/c also adds a lot of heat to the engine bay which will cause more timing to be pulled. I do believe the computer cuts out the compressor under wot. I had a 92 Grand Prix and under wot the blower motor would cut out also. The air would stop blowing out of the vents.
05 GTO A4- Svede otrcai, Fast 102, Livernois stg 2 ported heads, Texas Speed 224R cam, Pacesetter LT's, Edge 3000 stall, Kooks afterburners, Pedders 0 drp rear springs and shocks, MT et streets, 418rwhp/391rwtq, [email protected]
RJ_05GTO is offline
Driveshaft Question StoopidSlow Drive train, suspension, alignment and brakes. 3 06-14-2010 09:31 PM
dumb question about power,69 gto skuzzzusmcdevildog 1964-1974 Tempest, Lemans & GTO General Discussion 7 06-04-2009 06:32 PM
65 GTO Power Steering Rag Joint Question WideTrack 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 07-23-2008 08:09 PM
Driveshaft question spidersinmybed Drive train, suspension, alignment and brakes. 1 01-20-2007 08:37 AM
2004 SAP Installed - Question about the Rubber asteng88 2004-2006 GTO General Discussion 0 05-26-2005 05:31 PM
