Air bag light on - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-27-2013, 09:04 AM Thread Starter
Air bag light on
I left my driver side window cracked and it rained . My back floor board got wet and shortly after that my airbag light came on now it want cut off. Tried to reset it but the computer will not communicate with the one in the car does anybody have in suggestions
Shonedvs is offline
post #2 of 3 (permalink) Old 04-27-2013, 06:38 PM
First you have to remove the cause, which I would assume is the water.
Disconnect the battery and check all the connection under the console, the one with the gear shifter. Make sure they are dry and connected.
Dry any thing else with wiring that got wet, (fuse panel comes to mind)
Then get someone with a tech 2 to reset the code.
ppxstnr is offline
post #3 of 3 (permalink) Old 04-28-2013, 11:26 AM
The seat belt harness is tied to the air bag system. More than likely water there got the problem started. You'll have to start there and use a Tech II to reset the light
Air bag de-activate on 2004 GTO John Carlson 2004-2006 GTO General Discussion 5 08-11-2009 07:20 PM
air bag alarm dustyminpin 2004-2006 GTO General Discussion 1 06-05-2009 11:42 PM
Air bag FAULT GoatOnMeth Service, Maintenance and Technical Discussion 3 05-13-2009 09:47 PM
