Alignment already??? - Pontiac GTO Forum
post #1 of 19 (permalink) Old 10-08-2004, 11:16 PM Thread Starter
bsmcall's Avatar
I have 6400 miles on my baby and it's clear to me that even though the steering feels right, that my baby( GTO) needs aligned. The front tires are worn excessively on the inner shoulders.
Am I the only one???
Do any of you think that warranty will cover the alignment and the necessary rotation???
bsmcall is offline
post #2 of 19 (permalink) Old 10-09-2004, 11:05 AM
Could that be from excessive tire pressure? May want to check that out.
Goat666 is offline
post #3 of 19 (permalink) Old 10-10-2004, 03:39 PM
Warranty covers the alignment for the first year or 12,000 miles if I remember correctly.
TulsaGTO is offline
post #4 of 19 (permalink) Old 10-11-2004, 03:22 PM
It's not that uncommon for new cars to need an aligment, espcially cars being shipped all the way from across the world. I'm not sure if dealers check alignments, or even if all of them can, but typically the alignment is set at the factory. BUT, jossels and bumps from shipment, espically if teh car is tied down too tight/loose, or imporperly, can throw the alignment out. And a car that was just barley 'in spec' at the factory is not out of spec. I'm not sure what the acceptable range is for this car, but usually the 'in-spec' range is quite large, and even a car 'within spec' can have poor tracking, pulling, or tire wear.
Tiger is offline
post #5 of 19 (permalink) Old 10-12-2004, 07:12 PM
lisatw151's Avatar
Send a message via AIM to lisatw151
along those lines...would need of reallignment cause a shimmy in the steering wheel? i don't notice it pulling either way, but there's a pretty noticeable shimmy in the wheel at highway speeds...especially around 60mph. at my last oil change, they said they balanced the tires but the shimmy is still there...if not worse. any ideas?
lisatw151 is offline
post #6 of 19 (permalink) Old 10-12-2004, 10:28 PM Thread Starter
bsmcall's Avatar
My GTO does the exact same thing @ 62mph give or take. That's why I checked the tires. What I found was found excessive wear on the inside treadbar which clearly indicates an alignment problem. Alignment is scheduled for next week. I'll let you know if the shimmy @ 60 is gone or not.
bsmcall is offline
post #7 of 19 (permalink) Old 10-12-2004, 11:28 PM
lisatw151's Avatar
i think i'll call my dealership tomorrow and see if i can get it in soon. i'm due for another oil change anyway. plus, mine does something funky..poss w/the electrical system. when slowing down to a stop, clutch pushed in, when i get down to about 15mph, the headlights dim very briefly. obviously, more noticeable in the dark. very strange though. it only does it when the clutch is engaged and the rpm's are dropping. guess i'll have to ask them to hook it up to the obd
post #8 of 19 (permalink) Old 10-13-2004, 07:53 AM
Dimming lights could be a number of things...what other accessories do you ahve on? A/C, radio, etc? If you've got all of the above running, it may jsut be a strain on the alternator and a temporary voltage dip due to the alternator slowing down. Not sure waht the clutch would have to do with that, but stranger thigns have happened. Either that, or mabye a voltage regulator. Or of course, maybe nothing, and it's just another quirk, like the lack of central locking....gotta love those backwards Aussie's.
Tiger is offline
post #9 of 19 (permalink) Old 10-15-2004, 06:05 PM Thread Starter
bsmcall's Avatar
The dimming you see is normal to all the ls1 v-8's. I ranted and raved at my dealer over the same thing on my '98 Z-28. Then when I got this GTO, same thing. It's the electric air pump??? I think. All the GMC sierras in my fleet do the same thing. Enjoy the ride even if it has a quirk or two
bsmcall is offline
post #10 of 19 (permalink) Old 10-16-2004, 07:04 AM
Headlight issue-my 00 z28 did the same thing. Had it for 3 years replaced the battery once and never replaced the altenator. Dont worry about the lights. As for the shimmy at 60, could be a alignment issue or you could have a bad tire. I have seen a number of tires that have a slight defect from the factory that would cause such a problem. Check out the post on over-inflated tires from factory, that would cause a shimmy and excessive tire wear.
Davjefdunn is offline
