Anyone run into Warranty problems or other hassles w/ a Short Shift kit - Pontiac GTO Forum
post #1 of 16 (permalink) Old 01-25-2006, 11:48 AM Thread Starter
anyone run into problems w/ the dealer w/ a shift kit?
HotRodGuy is offline
post #2 of 16 (permalink) Old 01-25-2006, 12:00 PM
With a shift kit (auto) or a short shifter (6 speed)? If it's a auto then yes you will have issues if it's a six speed the no you should be fine.
GTODEALER is offline
post #3 of 16 (permalink) Old 01-25-2006, 12:11 PM
My Tremec fried soon after I installed my B&M sport shifter. Of course, the service department immediately zeroed in on this-- I must admit to being a bit freaked out about the possibility myself.
But, I did my research, held my ground, called bullsh1t whenever necessary, and eventually got my tranny replaced under warranty. In the end it turned out the failure mode was the tail bearing frying out...completely unrelated with the shifter bolted on the top of the housing.
So...don't worry about it.
Groucho is offline
post #4 of 16 (permalink) Old 01-25-2006, 12:42 PM Thread Starter
Thanks, what kind of run around did they try to give you?
post #5 of 16 (permalink) Old 01-25-2006, 04:21 PM
501 RWHP & 469 RWTQ
05GOAT's Avatar
I actually had the Dealer install mine. Then about a week later it feel through the console and I had no gears. They fixed and I had no hassles what so ever.
http://www.cardomain.com/ride/2094213 My Goat
05 M6
Polished Maggie
278/286 551/551 115 LSA Cam
Spec Stage 3+ clutch
LT Headers
LPE CIA
GMM Ripshifter
506 RWHP / 479 RWTQ
05GOAT is offline
post #6 of 16 (permalink) Old 01-25-2006, 04:28 PM
Short shifter should not be an issue. The transmission could not be hurt by this modification.
A local guy had that issue and another Pontiac dealership tried to void his warranty. Luckily I caught the issue and all was well./
dealernut is offline
post #7 of 16 (permalink) Old 01-25-2006, 05:00 PM
They (1) did a half-assed drain & fill, calling it good even though the tranny sounded like it was filled with gravel and had no reverese then (2) tried to say the warranty was voided by the B&M.
Idiots.
They eventually did pull their heads out of their as$ses and warrantied the tranny...it was a random failure, it seems.
That being said, avoid the B&M like the plague. I have had many problems isn keeping it attached to the transmission properly...It's OK now but it's been a long, pain-in-the-ass road.
The GMM is reportedly a much better design.
Groucho is offline
post #8 of 16 (permalink) Old 01-25-2006, 05:08 PM Thread Starter
yea, a quick use of the search function told me not to skimp and get the B&M
for those that had dealers install them, what did you pay?
post #9 of 16 (permalink) Old 01-25-2006, 06:50 PM Thread Starter
Originally Posted by gto500hp
I got a new motor, new seat rails, new door locks, 4 new knock sensors and 4rental cars. I am lookin into trading for an 06. I am waiting to see what happens next. Im at 13000 miles 3500 on new motor. and two months till drags start back up.
soooo, how does this relate to the Short Shifter?
post #10 of 16 (permalink) Old 01-26-2006, 12:56 PM
what did you pay?
We charge $150.00
