Automatic Transmission fluid change/details - Pontiac GTO Forum
post #1 of 6 (permalink) Old 03-18-2014, 06:05 PM Thread Starter
I want to change the ATF fluid/filter(s) in my '04 GTO. Currently at 55k miles. All highway driving. Daily driving to and from work. Always (well most of the time) driven easy.
i couldn't find any details on the forums as far as how many quarts drain out when you do a drain/fill. Would a simple fluid change be good enough? or do you guys recommend taking it somewhere and flushing out and replacing all the fluid??
Rgrafton is offline
post #2 of 6 (permalink) Old 03-18-2014, 06:24 PM
HP11's Avatar
Quoted: 24 Post(s)
According to the service manual:
Automatic Transmission fluid and filter (Drain and Refill) 5.3 quarts DEXRON-III
It is suggested to change it ever 50000 miles for normal use and every 25000 miles for severe service. Your description sounds like normal service. In both cases they say 'change' rather than flush.
HP11 is offline
post #3 of 6 (permalink) Old 03-18-2014, 06:40 PM Thread Starter
thanks for the info!
any experience with Amsoil ATF? I think I'm going with the Signature Series.
Rgrafton is offline
post #4 of 6 (permalink) Old 03-18-2014, 07:11 PM
HP11's Avatar
Quoted: 24 Post(s)
All it says is Dexron-III and to look for 'Approved for the H-specification" on the label. I'm fairly sure that Amsoil meets that spec.
HP11 is offline
post #5 of 6 (permalink) Old 03-26-2014, 08:03 PM
holset35's Avatar
Did mine last summer used Royal Purple.Have not seen any problems yet.
holset35 is offline
post #6 of 6 (permalink) Old 04-09-2014, 03:00 PM
SIXO GTO's Avatar
I use Redline D4 atf in my M12 6 spd . Dex-IIIh rated tranny shifts like butter !
SIXO GTO is offline
Going change fluid in my t56 SIXO GTO Drive train, suspension, alignment and brakes. 5 03-25-2014 05:07 AM
67 GTO with leaking transmission; automatic jimmy328 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-27-2012 10:42 PM
Automatic transmission fluid for power steering? iwant2buyaGTO Service, Maintenance and Technical Discussion 5 02-09-2012 07:25 PM
Fluid Change Intervals SnKGoat Service, Maintenance and Technical Discussion 8 06-25-2010 04:10 PM
Automatic Vs. Manual Transmission drosene Service, Maintenance and Technical Discussion 17 09-11-2007 04:06 PM
