battery connected backwards - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-12-2016, 12:48 AM Thread Starter
2005 GTO batteryou connected backwards for a few seconds the negative terminal got red hot, switched it back to normal and started car back up , let it idle for 10 mins (said check alternator on dash) after 10 minstrel of idling the alternator started smoking... should I new alternator +alternator wire+fuses fix the problem?
sskillaz is offline
post #2 of 2 (permalink) Old 06-12-2016, 05:34 PM
Yes, if you're lucky you didn't whack some electronics.
1970 GTO 400 backwards connecting rods? uh... oilburner66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 10-05-2012 10:30 PM
When your battery was dead, did your battery light stay on? SueY816 2004-2006 GTO General Discussion 7 05-31-2010 05:54 PM
One step backwards crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 04-15-2010 09:15 AM
