Battery tender/storage question - Pontiac GTO Forum
post #1 of 7 (permalink) Old 12-04-2015, 11:08 AM Thread Starter
dave1's Avatar
This might be a silly question but I just bought a Deltran battery tender plus for my 06 GTO that I'm storing for the winter. I'm leaving the battery in the car do you guys connect the negative of the tender to the car battery or the engine block? Thanks
dave1 is offline
post #2 of 7 (permalink) Old 12-04-2015, 11:25 AM
I have always connected mine to the - terminal of my optima red top battery, then to the +, then plug into the wall. I am pretty sure it won't charge unless it is connected to the + and - negative battery terminals.
meekergto is offline
post #3 of 7 (permalink) Old 12-04-2015, 01:33 PM
It should work either way as the block is connected to the negative side of the battery.
post #4 of 7 (permalink) Old 12-04-2015, 01:41 PM
Put the tender on the battery as it is a battery tender. Mine came with a harness that stays attached to the battery all of the time and I have the line with plug from the tender hanging down by my car. The tender sits on top of the garage door opener. Whenever I don't drive it for more than a few days I just plug it in.
post #5 of 7 (permalink) Old 12-05-2015, 07:05 AM
HP11's Avatar
Quoted: 24 Post(s)
It will charge if the positive is connected to the battery and the negative is connected to any ground point on the car. Until it's actually plugged in it doesn't matter what order you connect them as long as they are connected to the proper terminals.
HP11 is offline
post #6 of 7 (permalink) Old 12-05-2015, 10:05 AM
You could technically hook the positive up to the alternator and the negative to the tail pipe but it seems kind of silly as like I said the tender is for the battery why not keep it simple
post #7 of 7 (permalink) Old 12-08-2015, 07:56 AM
the instructions that came with mine said to connect it to the battery but as others have said....it should work either way
88redconvert is offline
Battery Question mtlmark Service, Maintenance and Technical Discussion 26 09-19-2011 10:22 AM
Connecting a battery tender Goat67 1964-1974 Tempest, Lemans & GTO General Discussion 12 10-07-2010 01:01 PM
Battery Tender...Connections... silversport Service, Maintenance and Technical Discussion 8 02-11-2009 10:06 PM
Battery Question MeanGoat Service, Maintenance and Technical Discussion 3 06-14-2007 06:06 PM
