BCM Install for Airbag fault 40 GTO - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-21-2015, 02:00 PM Thread Starter
Hello!
Rockauto has new BCM. It mentions separate purchase for key FOB and BCM has label for security code.
Do I just remove and plug-in new BCM?
Or is there a program setup process required?
This is to stop the airbag fault light. Auto electric guy says there is no code behind the light, so he thinks maybe BCM bad.
Please help me keep my GTO, so I can stop myself from buying a Mustang.
Aloha,
Eric
Eric Sakai is offline
post #2 of 3 (permalink) Old 12-21-2015, 03:21 PM
AlaGreyGoat's Avatar
I would take it to a known good air bag specialist.
Some systems require a special code reader for
air bags.
Larry
AlaGreyGoat is offline
post #3 of 3 (permalink) Old 12-21-2015, 04:35 PM
I'd take it to a GM dealer. It may be something they can reset with their Tech II. Also if you get a BCM you'll need to have someone link the BCM and PCM together.
airbag fault and hot weather ufgator Service, Maintenance and Technical Discussion 3 06-16-2019 09:36 AM
Airbag Fault? FireChicken Service, Maintenance and Technical Discussion 13 05-22-2018 08:46 PM
Fuel Gauge Error/ABS Fault/Airbag Fault camoore81 Service, Maintenance and Technical Discussion 6 10-26-2015 03:37 PM
Airbag Fault nytmaregto 2004-2006 GTO General Discussion 4 07-20-2015 07:40 PM
AirBag Fault DJ_YellowGTO Service, Maintenance and Technical Discussion 1 02-02-2005 08:45 AM
