Belt Squeal! - Pontiac GTO Forum
post #1 of 6 (permalink) Old 01-14-2016, 07:40 PM Thread Starter
Belt Squeal!
Hey everybody, I've recently noticed that the belt would start to squeal quite loudly roughly 15min into driving. First I threw a new belt at it (nothing fancy a duralast) but it didn't help. I then noticed it was leaking coolant and threw a new water pump at it, fixed the leak but it still squeals. It's honestly driving me mad; any ideas on what the next step would be??
bryanpv670 is offline
post #2 of 6 (permalink) Old 01-14-2016, 07:56 PM
Check the tensioner, if it is good then while it's running put something dry on the belt. Baby powder, baking soda etc. It should stop squeaking.
post #3 of 6 (permalink) Old 01-15-2016, 06:41 PM Thread Starter
Thanks for the tip I'll try it out soon. Although I have noticed that the squeal goes away after like 10mins. Would a bad tensioner not be constantly squealing? I've also had all the pulleys checked with no sign of any of them being the culprit.
post #4 of 6 (permalink) Old 01-15-2016, 08:27 PM
dave1's Avatar
I had the same thing definitely change the tensioner, did you also change the air conditioning belt?
dave1 is offline
post #5 of 6 (permalink) Old 01-15-2016, 10:22 PM Thread Starter
Hmmm hadn't thought about the AC belt since I rarely use the damn thing. Wouldn't the squeal change with the turning on and off of the AC? I'll probably slap on a tensioner first then get to the belt...
post #6 of 6 (permalink) Old 01-16-2016, 03:11 AM
Hey Bryan,
I had a slight squealing under my hood similar to yours, but not quite as loud.
I ended up changing out the belts, the tensioner, and the pullies.
I didn't bother with the process of elimination, because I had no idea what the previous owner had done service wise, and I felt more comfortable with having known what's been serviced under the hood.
Needless to say, no more squealing.
2006 GTO, Cyclone Grey
Mods: Magnaflow Exhaust
Forum Poster is offline
Squeal when rolling slowly Mike's06GTO Service, Maintenance and Technical Discussion 1 10-24-2013 11:00 AM
Loud Squeal!!! Weisberg16 Engine Discussions 11 02-15-2011 07:52 PM
Extended chirp/Squeal between 1st and 2nd gear MiloGTO 2004-2006 GTO General Discussion 4 07-02-2009 11:16 AM
C5 brake squeal PEARL JAM 2004-2006 GTO General Discussion 2 06-06-2007 09:45 AM
Tire Squeal........ Goat Herder 2004-2006 GTO General Discussion 10 07-15-2005 01:36 PM
