A/C Problem - Pontiac GTO Forum
post #1 of 6 (permalink) Old 06-14-2005, 07:17 PM Thread Starter
A/C Problem
If my A/C is set for my vents and I start to go up an incline or accelorate quickly it will start coming out my defrost and go back when I go back to normal conditions. is that normal for an 04?
Keith'sGTO is offline
post #2 of 6 (permalink) Old 06-14-2005, 07:46 PM
that is definetly not normal, take it in and explain it to the tech at the dealer
Braman'sGTO is offline
post #3 of 6 (permalink) Old 06-15-2005, 09:05 AM
....sounds like a vacuum problem....I could be wrong..
GTODEALER is offline
post #4 of 6 (permalink) Old 06-15-2005, 06:17 PM Thread Starter
Ok I took it into the shop today. They said it was the switch and fixed it. Then I left and guess what same thing. I went right back now they want me to leave it a couple of days so they can figure it out.
post #5 of 6 (permalink) Old 06-15-2005, 07:39 PM
I use to do A/C work and I can tell you that most guy's in the automotive mechanic business dont know sh1t about AC, alot of them are only parts changers and will continue to change parts untill the ac workes. Luckely there are fewer components in a car that will break so it should'nt take a compitant tech long to fix it.
post #6 of 6 (permalink) Old 06-15-2005, 08:44 PM
It is a vacuum line problem of some kind. I had the same problem on another car. Look for a loose or broken vacuum line.
DuaneGTO is offline
