CAI Causing Check Engine Light.....? - Pontiac GTO Forum
post #1 of 17 (permalink) Old 02-27-2006, 02:19 AM Thread Starter
I have a '04 with a New Era CAI, other wise stock. The car set a (left & right bank) Lean code. Has anyone else had this problem after installing a CAI???
Is this normal?
Any help would be appreciated!
Travix
BlownGTO is offline
post #2 of 17 (permalink) Old 02-27-2006, 05:43 PM
fergyflyer's Avatar
I've heard of 05's throwing codes with a CAI, but not the 04. Try starting over with the install. Make sure there isn't anything loose or not seated properly. If everything appears to be on correct then disconect the battery and clear the code. This time do not immediately get on it, but kinda let the computer get adjusted to having the less restrictive intake.
fergyflyer is offline
post #3 of 17 (permalink) Old 02-27-2006, 05:50 PM
johnebgoode's Avatar
Disconnect the battery for 30 mins. This will let computer wind down. Make sure all your wiring for MAF is connected properly. Check for bent or mis aligned pins in the connector ,reconnect battery.
johnebgoode is offline
post #4 of 17 (permalink) Old 02-27-2006, 06:17 PM
SoGaGTO's Avatar
I was discussing CAI with my dealership (maint. mgr.) and he told me one of the brands would leak oil and cause the check engine light to come on. I believe it was the New Era CAI but I'm not sure. He said they haven't had any trouble with the K&N CAI. I have a 2005 so I'm not sure this applies to the '04s.
SoGaGTO is offline
post #5 of 17 (permalink) Old 02-27-2006, 06:32 PM Thread Starter
Yea I did that on Saturday to reset the SES light and clear the code. Ive already checked all the MAF connections. It set the light almost a month after I installed the CAI.
BlownGTO is offline
post #6 of 17 (permalink) Old 02-27-2006, 07:31 PM
hmm are we sure it's the CAI then? I mean, the MAF is there to determine how much fuel to send to the cylinders, not complain when it's getting more air than stock. If they all did that, dry nitrous kits wouldn't work.
CrabhartLSX is offline
post #7 of 17 (permalink) Old 03-02-2006, 12:50 PM
A month would give that oil about the right amount of time to build up on the MAF. You might want to have a look at it to make sure there's no dust/dirt/oil on there. That could absolutely cause a lean condition. The MAF can't read the correct amount of air that's actually going into the intake.
I'd try the battery thing first, since it's the easiest though.
baron_iv is offline
post #8 of 17 (permalink) Old 03-02-2006, 12:55 PM
.....you do realize that's a K&N filter on the end of that New Era cai...... if the filter is "over-oiled" then you may have issues, but, as soon as you reset the light it would trip it almost immediately. GM has a tsb on the K&N filters, maybe you service manager was getting confused. No biggie.....
GTODEALER is offline
post #9 of 17 (permalink) Old 03-02-2006, 01:06 PM
PHOTOGOAT's Avatar
[QUOTE=GTODEALER GM has a tsb on the K&N filters, [/QUOTE]
Does this TSB include stock K&N replacement filters? If so, what does it entail? Just curious......I recently purchased a K&N replacement filter for the '05.
2005 GTO
PBM, RI, A4 with 18" wheels
One of 68
78 Trans Am
46,000 miles, BBC 402
4 speed
Custom automotive photography services available.
PHOTOGOAT is offline
post #10 of 17 (permalink) Old 03-02-2006, 07:01 PM
hmm maybe spring for a foam or non-oiled replacement filter and see if that fixes it.
Is the GTO MAF any different from an F-bodies? The 04 i mean?
