Can I clear airbag light by disconnecting the airbag module? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 10-14-2014, 04:34 PM Thread Starter
Hello everyone. Recently I had reached out and kindly received feedback on my plight to clear the darn airbag warning light/beeping on my '06 GTO. It was about which scanner to use to clear the airbag light for last GTOs. I had disconnected the airbag seat wiring and later turned the key "ON". Bad move... I had bought an Autel MaxiDiag Elite {that Chinese company's highest level scanner, I think} but they DON"T tell you it does not access SIR/SRS/airbag systems. Anyway, I'm just about to bite the bullet and go to a rip-off GM dealer to get the code/light cleared {$100 plus/5 min of "work"}. But I just though of a final, possible solution: if I disconnect the airbag MODULE'S connector, will that kill the keep-alive-memory within that module? Yeah, I know/learned that disconnecting the car's main battery does not clear the SIR code/light. But perhaps, hopefully, disconnecting the airbag module {found in the rear of the console} will finally do the trick. Anyone knows, before I tear the console apart???? Thanks in advance.
gpepiton is offline
post #2 of 2 (permalink) Old 10-14-2014, 06:28 PM
Don't think so. It is still going to take a high end tool like a TechII to do it.
airbag question!! travy082 Interior Discussions 2 03-15-2009 12:31 PM
Airbag? LITTLE GTO 2004-2006 GTO General Discussion 2 01-22-2006 09:19 PM
AirBag Fault DJ_YellowGTO Service, Maintenance and Technical Discussion 1 02-02-2005 08:45 AM
