Car noise - Pontiac GTO Forum
 1Likes
  • 1 Post By GTO44
post #1 of 2 (permalink) Old 04-13-2019, 08:40 AM Thread Starter
Cdidy97's Avatar
Car noise
Hey guys. I have a 04 GTO. If I take off to fast, my car makes kind of a stutter sound coming from the back of my car. (Sounds almost like a rev limiter. I can also feel it. Does anyone know what this might be?
Cdidy97 is offline
post #2 of 2 (permalink) Old 04-13-2019, 02:18 PM
GTO44's Avatar
Quoted: 37 Post(s)
Driveshaft center carrier bearing. Check the rubber, most likely torn. Will sound like rapid thuds until a high enough rpm or low enough load and it goes away. Replace it quick as it can wear out your trans tail shaft seal.
Stephen Blakeney likes this.
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
66 GTO 389 Tri - "Screeching" noise when car first starts jgotzens 1964-1974 Tempest, Lemans & GTO General Discussion 9 08-08-2014 01:06 PM
Strange werrrrreeeeeeeeee noise coming from front of car Sciggy Service, Maintenance and Technical Discussion 22 06-24-2012 09:31 AM
Whistling noise when starting up car? rmd83082 Service, Maintenance and Technical Discussion 3 10-21-2011 12:22 PM
Transmission issue, grinding noise and car won't move Goatman455 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 17 09-29-2011 10:03 PM
Hight Pitched Noise On First Start GOTdriver04 Service, Maintenance and Technical Discussion 3 10-18-2004 03:23 PM
