Car running lean - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-09-2015, 09:30 PM Thread Starter
Jarzone's Avatar
Car running lean
I have a 2006 GTO with intake, headers, exhaust and tuned. I got the car tuned back in September and just yesterday my check engine light came on saying bank 1 and bank 2 are running lean. Need help on what it could be. Thanks
Jarzone is offline
post #2 of 3 (permalink) Old 11-10-2015, 04:48 PM
Fuel pressure should be one thing to check. The MAF and connections would also be a good thing to check. Any vacuum leak past the MAF can cause a lean condition. What "intake" do you have?
post #3 of 3 (permalink) Old 11-10-2015, 09:01 PM
Lemans guy's Avatar
Quoted: 54 Post(s)
Spot on advice, I would just build on that advice and say that both banks reading lean eliminates an individual fuel injector problem for example and points to any system that effects the total fuel air delivery......
It can mean too much air.......or not enough fuel.....
Too much air, vac leak as described or some other say,...stuck open dirty Idle air control....
Or too little fuel....such as clogged fuel filter, weak fuel pump, bad fuel pressure regulator.....
These modern cars are very sensitive to fuel pressure, just a few psi off and it will effect the systems, check that fuel pressure first!
Lemans guy is offline
13 Maintenance Tips to Keep Your Car Running Smoothly AutoGuide.com In the News 0 03-11-2015 02:50 PM
Anybody running Pro Car seats, or others in their 66 or 67 scrapmaster 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 02-11-2014 04:51 PM
is my car running to hot?? 2004goat 2004-2006 GTO General Discussion 1 07-17-2010 12:42 PM
Everything quit while car is running?!? 72 GTO MescaBug 1964-1974 Tempest, Lemans & GTO General Discussion 4 06-30-2010 10:43 PM
is my car lean?? Bluegoat05 Service, Maintenance and Technical Discussion 6 06-23-2010 07:57 PM
