Catch Can - Pontiac GTO Forum
post #1 of 9 (permalink) Old 12-07-2005, 01:31 PM
Rob in CT
Guest
Posts: n/a
Quoted: Post(s)
Catch Can
Sorry to sound ignorant, but what the hell is a catch can?
I have worked in the field for nearly 15 years, and the only catch can i know of is in NASCAR when refueling the car.
post #2 of 9 (permalink) Old 12-07-2005, 01:32 PM
big_mike
Guest
Posts: n/a
Quoted: Post(s)
essentially the same thing, but basically it catches oil from somewhere, so it dont go somewhere else.
I cant remember EVERYTHING that is said.......
post #3 of 9 (permalink) Old 12-07-2005, 01:35 PM
johnebgoode's Avatar
johnebgoode is offline
post #4 of 9 (permalink) Old 12-07-2005, 01:35 PM
The catch can will remove oil particles from the PCV hose that runs from the crankcase into your intake. Those that have them state they pull out about a tablespoon of oil every few thousand miles.
WEDJ is offline
post #5 of 9 (permalink) Old 12-07-2005, 01:36 PM
Originally Posted by johnebgoode
Goes to Nextel??
WEDJ is offline
post #6 of 9 (permalink) Old 12-07-2005, 01:36 PM
Originally Posted by WEDJ
Goes to Nextel??
Fixed it...........
post #7 of 9 (permalink) Old 12-07-2005, 01:39 PM
big_mike
Guest
Posts: n/a
Quoted: Post(s)
this should be a sticky too.
post #8 of 9 (permalink) Old 12-07-2005, 02:01 PM
Rob in CT
Guest
Posts: n/a
Quoted: Post(s)
Seems like a lot to go through for a teaspoon an oil change.
post #9 of 9 (permalink) Old 01-22-2007, 09:16 PM
Hey All,
Even though the teaspoon or so of oil being used does not seem like much, it is not the consumption, but rather what it does.
The build up of oil in the intake then into the combustion chamber can lead to the tops of the pistons becoming covered with carbon buildup. This carbon build up can lead to spark knock causing the computer to reduce timing and therefore reduce power. There are a lot of folks that cam tolerate a small loss of oil between oil changes, but not too many will tolerate a loss of power in a performance car.
Here is a unit we had manufactured for us and fell free to e-mail or PM me for info. Hope this info helps.
Mike Norris
ID:	971   Click image for larger version
ID:	972   Click image for larger version
Mike Norris is offline
