Changing Coolant - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-29-2010, 11:26 PM Thread Starter
GTOMOE9's Avatar
Changing Coolant
i know this is lame as **** but i cant seen to figure out how to change the coolant in the goat can someone help me out and give me some tips thanks
GTOMOE9 is offline
post #2 of 4 (permalink) Old 07-02-2010, 04:55 AM
B-ville Goat's Avatar
Radiator drain is at the bottom driver side corner on the side tank. Can be tough to see, you may need to get underneath to find it.
Vice President
Susquehanna Valley GTOs
B-ville Goat is offline
post #3 of 4 (permalink) Old 07-02-2010, 07:03 AM
jpalamar's Avatar
If you can't find it, just pull the lower rad hose off. Its better then nothing but will make a slight mess.
jpalamar is offline
post #4 of 4 (permalink) Old 07-02-2010, 09:38 AM
GM4life's Avatar
From the picture it looks like you have a 05+ they have a drain kok like B-ville said. 04 GTO's don't have one and you have to pull the lower radator hose like Jpalamar said.
GM4life is offline
Coolant question..... 6point0 goat Service, Maintenance and Technical Discussion 5 07-01-2010 03:30 PM
Opinions on changing or not changing my exhaust. vance_pounders 2004-2006 GTO General Discussion 4 12-22-2009 06:39 AM
Coolant smell oldstyle81 Service, Maintenance and Technical Discussion 11 07-23-2009 08:07 PM
help coolant stick thispecialk 2004-2006 GTO General Discussion 6 12-28-2008 08:22 AM
coolant overflow Pontiac Tempest Cstm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 08-04-2008 09:18 AM
