Changing slave cylinder and clutch someone help! - Pontiac GTO Forum
post #1 of 2 (permalink) Old 10-08-2014, 07:07 PM Thread Starter
So I'm driving my 05 GTO and the clutch stopped working, I stopped and checked the fluid and it was gone. I filled it and pumped the clutch and all of leaked from the bottom of the tranny. I believe its the slave cylinder but I'm not sure. Anyway I bought a new one but my mechanic is telling to buy a new clutch so that I wont have to pay the labor again later. If I get a stage 2 clutch do I have to change other parts?
Mayen91 is offline
post #2 of 2 (permalink) Old 10-09-2014, 10:30 AM
It's almost undoubtedly the slave. The only thing I would add for sure is a remote bleeder. Besides making it easy to bleed it also allows easy and complete flushing of contaminated fluid down the road. Just to be safe I would also measure the PP fingers to bell housing mounting surface and TOB to trans face distances to see if you need a shim on the slave or not. The distances are pretty critical and just slapping in parts can make for going back and redoing things.
clutch slave cylinder o4gto 2004-2006 GTO General Discussion 0 09-14-2011 07:34 PM
Clutch Slave cylinder riley70usmc Drive train, suspension, alignment and brakes. 3 12-26-2010 02:21 PM
Air in clutch fluid or slave cylinder? SplitFire Drive train, suspension, alignment and brakes. 3 12-11-2010 12:21 PM
Help changed slave cylinder still no clutch Justinbel4 Service, Maintenance and Technical Discussion 6 08-31-2010 09:55 AM
Clutch Slave Cylinder AUTOSLIM50 Drive train, suspension, alignment and brakes. 10 05-07-2010 05:21 AM
