Check Engine Light On after key removal? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-03-2011, 08:38 PM Thread Starter
Hi, new to the forum...
Just wanted to know. When I start car all the lights start (brake/ abs/ check engine etc...) but then after a bit they all go off.
I've noticed thought that if I turn the key to the ignition and then turn it off and take off the key the check engine light stays on for about 4 secs then it goes off. Is that normal?
USMCSKYLINE is offline
post #2 of 3 (permalink) Old 02-13-2011, 04:08 PM
Mine does the same exact thing. I am not really sure if they all do that. Maybe there is code that needs to be cleared???
Weisberg16 is offline
post #3 of 3 (permalink) Old 02-19-2011, 07:24 AM
All indicator lamps come on when key is turned to on, this is a bulb check. If these lights stay on for a few seconds after being started it is normal. If you had a code it would stay on.
LS1 John is offline
Check engine light GuatoLT1 2004-2006 GTO General Discussion 5 11-03-2010 08:57 PM
Check Engine Light? koolkam89 Service, Maintenance and Technical Discussion 6 04-19-2010 01:48 PM
Check Engine Light!!! dustyminpin 2004-2006 GTO General Discussion 23 10-24-2009 04:54 PM
Check Engine Light 04YJ-GTO Intake and Exhaust Discussions 16 04-30-2008 06:27 PM
Check engine light? fright88 Service, Maintenance and Technical Discussion 5 02-27-2007 11:53 PM
