Check Engine Light- Emission Leak! - Pontiac GTO Forum
post #1 of 7 (permalink) Old 05-22-2010, 04:00 PM Thread Starter
PetMyGoat's Avatar
I am continually receiving a check engine light on my stock 04 GTO. When the OBDII reader is plugged up, I get a p0442 code. When code manual referenced, it says it is this is a emission leak. I have been told this is common due to bad gas cap. It's been replaced and still get check engine light couple days after erasing code. What else to consider???
PetMyGoat is offline
post #2 of 7 (permalink) Old 05-22-2010, 05:15 PM
AlaGreyGoat's Avatar
May want to check the vacuum hoses on the charcoal canister between
the rear wheel. It's next to the rear end chunk. I knocked a hose off mine
while mounting my airbags, and had the same problem you are having.
Larry
AlaGreyGoat is offline
post #3 of 7 (permalink) Old 05-22-2010, 06:14 PM Thread Starter
PetMyGoat's Avatar
Thanks Larry! I will look into that.
post #4 of 7 (permalink) Old 05-22-2010, 07:44 PM Thread Starter
PetMyGoat's Avatar
Is the charcoal canister black, rectangular looking box? Thats the only thing I see with some hoses coming out of it. If so, they seem pretty snug....
post #5 of 7 (permalink) Old 05-22-2010, 08:31 PM
646904GTO's Avatar
Yep thats the cannister
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
post #6 of 7 (permalink) Old 05-23-2010, 07:13 AM
jpalamar's Avatar
Probally the gas cap. I'd replace it again. As small of a leak that is needed to cause the CEL, you will have a tough time finding it without a gas test.
My old Sebring had this CEL and it ended up not being the gas cap. Took it to a good shop and they ran the gas test 3 times and couldn't find the leak. I got pissed and just put zip ties on the end of each hose back there and my problem was fixed. Guessing it is because they glue the hoses rather then clamping them. Maybe the glue doesn't last forever.
04 GTO - sold
jpalamar is offline
post #7 of 7 (permalink) Old 05-23-2010, 10:24 AM
You need to do the smoke test, or flash the code out.
Poncho Dan is offline
Check engine Light ixijustinixi Intake and Exhaust Discussions 3 07-09-2009 03:09 PM
Check Engine Light 04YJ-GTO Intake and Exhaust Discussions 16 04-30-2008 06:27 PM
Check Engine Light! 06BLUEGTO 2004-2006 GTO General Discussion 2 08-17-2007 10:01 PM
Check engine light? fright88 Service, Maintenance and Technical Discussion 5 02-27-2007 11:53 PM
Check Engine Light Wing_Nut Service, Maintenance and Technical Discussion 12 04-26-2005 01:00 PM
