Check engine light P1682 - Pontiac GTO Forum
post #1 of 5 (permalink) Old 04-03-2013, 06:51 PM Thread Starter
i have a 2006 GTO Manuel and my check engine light came on and reads P1682, can anyone tell me what that mean and what should i do to get rid of it?
NAS GTO is offline
post #2 of 5 (permalink) Old 04-03-2013, 07:29 PM
HP11's Avatar
Quoted: 24 Post(s)
The only time I've ever seen that code (not on a GTO) it had to do with low battery voltage during or prior to cranking and starting. In our case it turned out to be a bad connection at the starter on my wife's HHR. Other things could cause it like low battery voltage during starting, a bad ground cable etc. FWIW.
HP11 is offline
post #3 of 5 (permalink) Old 04-03-2013, 07:41 PM Thread Starter
I never have troubles starting my car, i just turned the check engine off just last week and it still hasn't showed up ever since, battery is new, would i need to change the alternator maybe?
NAS GTO is offline
post #4 of 5 (permalink) Old 04-03-2013, 09:03 PM
HP11's Avatar
Quoted: 24 Post(s)
If the CEL hasn't come back just make sure your battery connections are good and you should be okay.
HP11 is offline
post #5 of 5 (permalink) Old 04-03-2013, 09:51 PM Thread Starter
sounds good thanks man
NAS GTO is offline
Check engine light GuatoLT1 2004-2006 GTO General Discussion 5 11-03-2010 08:57 PM
Check Engine Light? koolkam89 Service, Maintenance and Technical Discussion 6 04-19-2010 01:48 PM
Check Engine Light!!! dustyminpin 2004-2006 GTO General Discussion 23 10-24-2009 04:54 PM
Check engine light? fright88 Service, Maintenance and Technical Discussion 5 02-27-2007 11:53 PM
Check Engine Light Wing_Nut Service, Maintenance and Technical Discussion 12 04-26-2005 01:00 PM
