chirping/sqeaking noise - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-05-2012, 12:38 AM Thread Starter
So i'm new to the forum but i've got a question for you guys. I have a stock 05 GTO (65000 miles) with the LS2 and 6 speed and i've been getting a chirping/sqeaking noise.
Crank it up in the morning rain or not and it chirps just like a belt, start to go down the road the sqeak speeds up with the rpm, depress the clutch and as the rpm drops the chirp stops. After you drive it for 10 or so minutes the sqeak seems to go away. I've replaced both belts and checked all the main drive belt pulleys, all turn freely with no pits or grooves in the pulleys.
I'm going to check into the AC belt pulleys soon but I was curious if someone had run into the same problem. Hoping it won't be a throwout bearing and will be a quick fix. Any input is appreciated. Thanks guys.!
THEGOATLS2 is offline
post #2 of 3 (permalink) Old 11-05-2012, 04:31 AM
B-ville Goat's Avatar
I have the same problem on my '03 Silverado, turned out to be the little belt for the A/C. If you can get to it while it's chirping, use a screwdriver, block of wood, whatever, to put more tension on that belt by pushing(lightly) on the tensioner and see if the sound changes. I usually replacde that tiny ass belt about once a year to keep it quiet until I started using gatorback belts on it!
Vice President
Susquehanna Valley GTOs
B-ville Goat is offline
post #3 of 3 (permalink) Old 12-02-2012, 03:47 PM
JPeezey's Avatar
Helpful advise... THANKS
Sent from my EVO using AutoGuide.Com Free App
JPeezey is offline
Noise ROBSGTO Service, Maintenance and Technical Discussion 7 11-05-2011 09:09 PM
Air Conditioner Causes Squeling/Chirping BlackJackByte Engine Discussions 8 09-03-2010 11:13 PM
Chirping Noise When Turning Left?! kdkiernan Drive train, suspension, alignment and brakes. 16 10-16-2009 06:51 PM
Chirping Sound While Driving Michael.Narlock Service, Maintenance and Technical Discussion 8 02-01-2009 12:05 AM
Rear chirping sounds when hitting bumps PatrickNJ Drive train, suspension, alignment and brakes. 10 09-03-2008 10:16 AM
