Clicking noise from rear - Pontiac GTO Forum
post #1 of 8 (permalink) Old 02-06-2016, 08:18 AM Thread Starter
So while driving the other day I started hearing a clicking noise from the rear of my car. When accelerating from a full stop it would start out slow and loud and gradually get faster and quieter unless I stepped on the throttle. The weird thing is that it went away for a few days completely and just recently started back up again. I checked the bearings and cv axles and both seem solid. Any ideas on what this could be?
bryanpv670 is offline
post #2 of 8 (permalink) Old 02-06-2016, 08:01 PM
I have this problem, not sure if the same cause because that description could be different things. I know that the cause for mine is the differential and posi needing repair. Its worse when I turn also, and not as bad when i am in neutral.
05GoatCali is offline
post #3 of 8 (permalink) Old 02-06-2016, 11:22 PM Thread Starter
Hmmm I had issues with my differential too up until a year ago. I replaced my seals and threw in some torco oil with some friction modifier. Haven't had any issues since.
post #4 of 8 (permalink) Old 02-06-2016, 11:23 PM Thread Starter
Also turning doesn't seem to affect the clicking whatsoever.
post #5 of 8 (permalink) Old 02-07-2016, 11:04 AM
Most owners posting rear end noises are 2nd - 3rd + owners of these cars and many don't know the initial issues with most rear ends from new. Also many of these used cars are inheriting a car what was abused, or raced, or used hard. Many previous owners never had the factory issues (if they had one) corrected and or never performed maintenance on the rear switching out the gear oil, and or if they did didn't know friction modifier was and is necessary to be installed.. the CORRECT type friction modifier.
Relying on a technician at your local GM dealer on what is causing this issue to correct it is a crap shoot at best. Unless you're lucky to have found one who worked for a Pontiac dealer back when this car was new, even still many didn't know this issue. When these techs don't know what is causing the issue, the rebuild is the answer but not necessarily the correct answer. I wonder how many utilize the TSB's that have notes on this issue.
Next I wonder how many read the stickies on this site that address many of the issues many who join this site with an issue to find the answer, get it from many of the knowledgeable ones on here then never revisit this site again.................unless they have another issue.
https://www.gtoforum.com/f3/growling-...ng-rear-14102/
post #6 of 8 (permalink) Old 02-07-2016, 01:03 PM
If it is the fluid modifier the clicking should only manifest when making turns where one wheel is traveling faster than the other. Hard to say but it sounds more like a CV joint.
post #7 of 8 (permalink) Old 02-08-2016, 05:13 PM Thread Starter
Hey everyone thanks for all the help. I made sure to put type f friction modifier in it back when I did it. I'm really starting to suspect the cv joint as well. Especially since the noise favors my rear right side and now seems to happen a little even when I'm not in gear. My next step is taking the damn thing out inspecting it.
post #8 of 8 (permalink) Old 02-14-2016, 07:10 AM Thread Starter
For anyone who stumbles upon this, it ended up being the cv axle. When trying to diagnose clicking from the rear of our cars it's a good idea to listen if it favors a side. If it does it could very well be a cv axle.
Clicking noise near flywheel? xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 03-26-2014 03:18 PM
Clicking noise when first started PennStateGTO Service, Maintenance and Technical Discussion 0 06-05-2011 09:41 AM
New wheel lip rings make clicking noise AzStateFan 1964-1974 Tempest, Lemans & GTO Wheels & Tires 2 09-21-2009 09:52 AM
clicking noise on dash gtoforspeed Service, Maintenance and Technical Discussion 3 11-26-2008 08:32 PM
clicking noise? DK2F Service, Maintenance and Technical Discussion 3 02-08-2006 06:25 PM
