Clicking sound - Pontiac GTO Forum
post #1 of 3 (permalink) Old 08-19-2018, 09:53 PM Thread Starter
Ohio66GTO's Avatar
Quoted: 14 Post(s)
Clicking sound
So I had a 455 in my 65 GTO and it wouldn’t turn over. After putting some gas and starting fluid in the carb it still would not turn over. I tried for a good 5-7 minuets cranking the engine, getting out and spraying the starting fluid, cranking and still nothing. After I gave up I got out of the car and heard a clicking sound. Sounded like it was coming either from under the valve cover, intake or carb. I came across a deal on a 428 so I swapped out the engines and today I went to fire up the 428 and had the same problem of it not turning over and the same clicking sound was there after about 5-7 minuets of trying to get it to start. The clicking goes away after about 5-7 minuets of it sitting. It’s not electrical, I don’t think, because I disconnected the battery and it still did it. Plus it sounds like it’s in the engine somewhere. I figured out why the 428 wouldn’t turn over but now I’m concerned about this clicking sound. Nothing was switched over to the 428 from the 455 either. Two completely different engines and the same clicking sound after not turning over. Any ideas??
Ohio66GTO is offline
post #2 of 3 (permalink) Old 08-21-2018, 02:55 PM
Quoted: 13 Post(s)
Just a wild guess. Maybe it wasnít a clicking but a dripping sound. Did you swap carburetors too or was it the same carburetor on both?
My theory is the float is broken, the carb is overfilling, and gas is dripping into the intake until it drips down to a level where it stops after 5 to 7 minutes.
Colorado67GTO is offline
post #3 of 3 (permalink) Old 08-21-2018, 06:38 PM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
hmm
possibly sounds like lifters bleeding down to me ...........
BLK69JUDGE is online now
Clicking sound form rear passenger tire BAMBAM Service, Maintenance and Technical Discussion 1 01-02-2010 11:18 AM
clicking mtullo Drive train, suspension, alignment and brakes. 0 11-24-2006 08:09 PM
Rattle-Clicking Sound in Back Seat PatrickNJ 2004-2006 GTO General Discussion 5 04-25-2006 06:36 AM
clicking noise? DK2F Service, Maintenance and Technical Discussion 3 02-08-2006 06:25 PM
fixed clicking sound HADAWS6 Service, Maintenance and Technical Discussion 1 12-14-2005 08:41 PM
