Clunking noise when gas pedal is pushed with video - Pontiac GTO Forum
post #1 of 5 (permalink) Old 03-09-2011, 06:11 PM Thread Starter
iwant2buyaGTO's Avatar
Go to youtube and set the settings to 480p and turn up the volume. At 12.5 seconds there is this noise sound like a gear from the front of my car. It clicks twice for about 1 sec. As soon as i push the gas pedal you can hear the noise. I dont know if this noise has been going on the whole time but i just recently starting paying attention to all the noises. This is me driving i have a video camera under my feet. The noise seems to be coming from the right front side of the car. This clunking sound only happens when i start my car and i push the gas pedal. It doesnt happen ever again until i shut off my car and push the gas pedal again. any ideas?
Also youll notice in the beginning of the video my steering wheel is making all kinds of noises. Any help with that as well?
http://img704.imageshack.us/img704/7973/gtoforum.jpg
iwant2buyaGTO is offline
post #2 of 5 (permalink) Old 03-12-2011, 10:30 PM Thread Starter
Does anyone know if this is normal?
post #3 of 5 (permalink) Old 03-13-2011, 01:31 PM
I'm having a hard time isolating what noise you're talking about. That shot is of the brake pedal...
Try inspecting/lubricating the throttle cable.
Poncho Dan is offline
post #4 of 5 (permalink) Old 03-13-2011, 02:24 PM Thread Starter
Its a very faint noise in the video. Turn the volume all the way up. You can hear it at 12.5 seconds. it sounds like "cluck cluck"
post #5 of 5 (permalink) Old 03-26-2011, 12:15 PM
KyleGT05usmc's Avatar
not sure if this will help but since the 04 is still drive by cable...
my camaro had an issue of clunking when i touched the throttle, it was literally the throttle cable came out of the keepers and was tapping on the cowl.
check to make sure the cable is secure the entire length
K&N CAI, lightly ported stock TB/INT, JBA Hpipe, Spintech Side Exh. ([email protected] r/t .8800 60' 2.06)
1/13/10- Kooks 1 3/4, LS7 Clutch, B&M shifter
1/21/11 - Eibach Springs, Monroe Shocks, EBC Brakes
Soon - "Sungold" PowderCoated 17"s
KyleGT05usmc is offline
clunking noise while turning trentwill83 Drive train, suspension, alignment and brakes. 3 12-16-2010 09:38 PM
rear clunking/clacking noise on 05 A4......... pctek Drive train, suspension, alignment and brakes. 34 08-15-2010 09:30 AM
Growling/Clunking Noise Coming from the Rear GTO JUDGE Service, Maintenance and Technical Discussion 0 08-28-2007 01:08 PM
clunking/popping noise - new struts? dustyminpin 2004-2006 GTO General Discussion 2 09-14-2006 03:30 PM
Clunking noise when using e-brake 04m6_ca Service, Maintenance and Technical Discussion 4 04-29-2005 05:58 PM
