Clunking noise when using e-brake - Pontiac GTO Forum
post #1 of 5 (permalink) Old 04-26-2005, 01:53 PM Thread Starter
When driving at any speed, in or out of gear, I get a clunking noise when I pull up on the e-brake. It makes the sound just as I feel the pads connect with the rotors. It may be normal, but wow, it is a serious "clunk". Has anyone else noticed this?
04m6_ca is offline
post #2 of 5 (permalink) Old 04-26-2005, 02:00 PM
b_a_betterperson's Avatar
Gotten it, but only when pulling the e-brake when coasting to a stop. I'm thinking it might be somewhat of a sticky cable or something like that. Don't think it's anything serious.
GTOs sit on a boat for a couple of months -- then, particularly with 04s, sit around for months more -- so maybe a lack of lubrication causes a bit of jolt until it's cycled a few times.
That said, it should clear up. If you can continually duplicate it -- best to write it down on your list of things to do the next time your car's at the dealership.
b_a_betterperson is offline
post #3 of 5 (permalink) Old 04-26-2005, 04:53 PM
Yeah, my 05 does the same exact thing. I've only tried it a few times so I don't know if it's somethig that will go away with some use on the e-brake or not...
-Rob
R_Andersen is offline
post #4 of 5 (permalink) Old 04-29-2005, 05:54 PM
Sorry to say...
Sorry guys. This was the first major thing I looked into when after buying my '05.
This condition is on all the GTO's (and apparently the C6 'vettes to, so I'm told).
I'll look for the thread I read somewhere that explains it in detail, but it is normal operation, unfortunately. Has to do with the *Parking* brake (notice I no longer call it an e-brake) is built into the inner diameter of the rear rotor, and when energized, it clunks majorly on the inner wall if the car is moving.
Why they would put a system like that on a performance car with a HAND activated parking brake is beyond me. But that's just the way it is. Nothing's broken or misaligned...
Again, sorry!
-WW
wwroller is offline
post #5 of 5 (permalink) Old 04-29-2005, 05:58 PM
Here's the link to the detailed explanation
Thread over at another board cleared this up for me:
http://www.newagegto.com/forum/index...pic=2887&st=0&
wwroller is offline
