Clutch fluid leak... - Pontiac GTO Forum
post #1 of 5 (permalink) Old 03-08-2013, 02:08 PM Thread Starter
I've been having clutch disengagement issues. Sometimes it's very easy and smooth to get into gear, and other times it grinds very slightly as I enter each gear. 1st is sometimes very difficult to engage. If they do grind, 2nd is always the worst. I've never noticed any trouble in 6th or reverse. I have to refill my clutch fluid reservoir every week. I've checked the bell housing, and there is no fluid which leads me to believe it isn't the slave, but I looked every around the master and inside and cannot find the leak... I have no idea if it is a stock or aftermarket clutch, but I'd say it's stock just from the feel. Pulls great in every gear, no slipping, and high RPM shifting isn't difficult. Any ideas what I should check before I drop $800 on a new clutch and tick master?
Metallifan is offline
post #2 of 5 (permalink) Old 03-08-2013, 04:49 PM
jpalamar's Avatar
Find level ground and stop. Put it into first gear with the clutch pushed down. Rev up the motor. If the car doesn't start to walk it likely isn't an issue with hydrololics.
04 GTO - sold
jpalamar is offline
post #3 of 5 (permalink) Old 03-08-2013, 05:42 PM Thread Starter
Will try that tomorrow. Thanks.
post #4 of 5 (permalink) Old 03-11-2013, 09:21 AM
If you're adding fluid every week and your carpeting isn't wet you have a leaking slave.
post #5 of 5 (permalink) Old 03-26-2013, 08:04 PM
your master cylinder might be bad and need to upgrade to a tik performance one
NAS GTO is offline
The battle of the trans fluid leak continues waltcoleman 1964-1974 Tempest, Lemans & GTO General Discussion 0 04-01-2012 07:10 PM
radiator fluid leak Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 6 06-21-2011 02:30 PM
radiator fluid leak Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 5 05-31-2011 10:43 AM
Replacing clutch fluid help pocketmaster Service, Maintenance and Technical Discussion 8 04-24-2011 03:58 PM
Clutch Fluid canadianGTO 2004-2006 GTO General Discussion 5 11-15-2009 01:58 PM
