Clutch killing the engine. - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-09-2007, 10:57 PM Thread Starter
I have a 66 GTO with a 400ci manual 4speed, and after the engine has wormed up and the car has been driven a little, if I sit their idling with the clutch engaged the engine will die and if I start it it will immediately die again unless i give it gas or put it in neutral and disengage the clutch. when the car is cold it acts normal its only after u drive it for awhile and worm it up that this problem occurs.
66 GTO is offline
post #2 of 4 (permalink) Old 10-10-2007, 12:34 AM
likethat's Avatar
maybe the throw out bearing is dragging it down or the pilot bearing
likethat is offline
post #3 of 4 (permalink) Old 10-11-2007, 10:57 PM Thread Starter
could someone tell me what kind of tranny fluid i should be using just incase i put the wrong stuff in.
66 GTO is offline
post #4 of 4 (permalink) Old 10-12-2007, 12:30 AM
likethat's Avatar
80-90 in most older 4speeds
likethat is offline
