clutch problem - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-24-2013, 06:26 PM Thread Starter
clutch problem
been doing alot of reading on here trying to see if others have the same problems. sitting at a stop light and all of a sudden the clutch wasnt disengaging completely. went to take off and it wouldnt go into second gear. stopped and checked the clutch master, and plenty of fluid and not dark. started to drive again and was rough for a couple minutes and then has been ok. at times going into gear it grinds alittle. car has 80k on it and ive had lots of gm cars with this drivetrain just not this many miles. i think its the clutch master and ive had another person say the same. i believe the clutch has been changed already. would like alittle feedback to make sure it seems like the clutch master to anybody else out there. thank you for any feedback.
bhrockstar is offline
post #2 of 4 (permalink) Old 03-03-2013, 07:13 PM
It is not common at all to have a bad master and usually they leak inside the cabin down by the floor. The slave or bleeding of the system could be the culprit. I would bleed the system at the bleeder while changing out the fluid and see if that helps first. It could also be the slave wasn't shimmed properly and as the clutch disk wore the slave can't extend far enough to disengage anymore. Most people just pop in a clutch set without the required measuring and shimming.
post #3 of 4 (permalink) Old 03-16-2013, 01:16 PM
Grambo427's Avatar
my 06 m6 does a similar kind of thing. but usually only at high rpm btw 3rd and 4th. no leaks in the cab but the fluid in the reservoir is dark. what's the easiest way to bleed these clutches?
Grambo427 is offline
post #4 of 4 (permalink) Old 03-16-2013, 01:18 PM
https://www.gtoforum.com/f3/t-56-tran...-manual-40649/
Clutch problem, please help!! New2thefamily Engine Discussions 12 02-11-2013 10:53 AM
Clutch Problem BlackoutV Drive train, suspension, alignment and brakes. 6 11-16-2012 10:19 AM
Clutch Problem, please help New2thefamily Service, Maintenance and Technical Discussion 4 12-28-2011 06:55 PM
05 GTo Clutch Problem sabastian458 Drive train, suspension, alignment and brakes. 8 05-10-2011 05:29 AM
Clutch adj. problem... Rock 1964-1974 Tempest, Lemans & GTO General Discussion 4 06-17-2006 12:49 PM
