Clutch and Slave cyl. Replacements.. Suggestions? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 08-19-2010, 04:00 PM Thread Starter
Mack04Goat's Avatar
I am having a new slave cylinder put in my ls1 GTO M6. While the trans. is dropped I am going to have a new clutch put in as well. My car is mainly a weekend car, nearly stock, and does not see the track very often. Any suggestions for the clutch as far as brands/models go? Any help is greatly appreciated. Thanks!
Mack04Goat is offline
post #2 of 7 (permalink) Old 08-20-2010, 06:50 AM
jpalamar's Avatar
LS7 clutch and flywheel
Tick slave and remote bleeder
SS lines
jpalamar is offline
post #3 of 7 (permalink) Old 08-25-2010, 07:23 PM Thread Starter
Mack04Goat's Avatar
thanks jpal. Kudos
post #4 of 7 (permalink) Old 08-27-2010, 01:14 PM
I have a 05 GTO and i just bought it. All of a sudden my clutch got weak and i had to add fluid. Now i have no clutch and no fluid in resevoir. The bottom of bell housing is wet. I am getting a new slave cylinder, i can get it from chevrolet for $280 but i found a website clutchcityonline.com and they offer a oem slave cylinder for on $98. Should i go with this, can i trust it?
Justinbel4 is offline
post #5 of 7 (permalink) Old 08-31-2010, 03:50 PM
george g's Avatar
buy the f-body slave and just change the fittings,yhey change by removing a pin.Buy the $98 one,that's what I run.
mods=stock 243s,85mm typhoon intake&tb,pacesetters&catless mids,85mm ls2 maf,svede otr,predator 224/231 cam,42# inj. and aComplete Street Performance dyno tune= 415/386
george g is offline
post #6 of 7 (permalink) Old 09-02-2010, 07:06 AM
87GN06GTO07IRL's Avatar
SS lines
87GN06GTO07IRL is offline
post #7 of 7 (permalink) Old 09-02-2010, 12:25 PM
For "average" muscle car use the LS7 is a good buy. If you go higher HP or drag the car a Monster Level 3 is the way to go. Myself, I've had the stock obviously, a Textralia, Spec 3+ and this Diamond 3 which was an earlier name for the Monster. By far the biggest disappointment was the Spec 3+. After 8,000 miles I threw it away. It couldn't hold over 400 RWHP, chattered and had "shim in, shim out" issues. After several years of different clutches having fanbois that later hated them the Monster has stood the test of time. Anyone remember the Bird of Prey clutch? For one summer it was all the rage and then reality hit.
Oh, and the above is correct. Do a remote bleeder and use a F-body slave with the fitting switched over. The slaves are all the same with the fitting different. You can get one for $80
Clutch Slave cylinder riley70usmc Drive train, suspension, alignment and brakes. 3 12-26-2010 02:21 PM
Clutch Slave Cylinder AUTOSLIM50 Drive train, suspension, alignment and brakes. 10 05-07-2010 05:21 AM
Engine swap, 250 6 cyl to 400 8 cyl Braveheart61 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-16-2009 12:28 PM
Slave Cyl? squrtdog50 Service, Maintenance and Technical Discussion 2 12-28-2008 05:06 PM
Clutch peddle hydraulic slave henryz Service, Maintenance and Technical Discussion 2 01-22-2008 07:33 PM
