Clutch or T56 - Pontiac GTO Forum
post #1 of 2 (permalink) Old 12-14-2013, 06:59 PM Thread Starter
Quoted: 6 Post(s)
Clutch or T56
I need a clutch in my 04' because the hydraulics are shot but I have noticed (in a big way) that sometimes the selector pops out of first. Sounds like the whole bottom of the car fell off, HUGE clunk. Could it just not be engaged because of the clutch or is it the syncros.
johnfin is offline
post #2 of 2 (permalink) Old 12-15-2013, 08:10 PM
NucciGOAT's Avatar
Wait.... You need a new clutch because your hydraulics are shot? How is a new clutch going to fix hydraulic issues? Is your clutch slipping? Not spinning the tires? RPM's go up but car doesn't go faster? If not then it's not your clutch.
If you have a hydraulic issue you need to look at your master cylinder and slave cylinder. One of those might be shot. Popping out of gear doesn't have anything to do with the clutch.. That's soley tranny issues.
You might want to take it somewhere and have them diagnose it for you. Then if your skilled enough do the work yourself. Sounds like you have more then one issue here
Sent from AutoGuide.com App
2004 yellow jacket M6: AEM intake, SLP LM2, 05/06 front brakes with DBA slotted rotors & hawk pads, B&M shifter, MSD wires, NGK TR55 plugs, Diablo predator tuned..
NucciGOAT is offline
putting a t56 into a 67 got??? 1967 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 09-10-2012 07:58 PM
t56 ccirfus 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 02-14-2012 05:31 PM
T56 woes fiddler_red Drive train, suspension, alignment and brakes. 13 07-20-2009 03:25 AM
T56 GNX231 2004-2006 GTO General Discussion 5 10-09-2007 04:52 PM
t56 overfilled? StarCaller Drive train, suspension, alignment and brakes. 6 06-18-2006 11:24 AM
