Coolant Leak - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-17-2015, 11:34 PM Thread Starter
pocketmaster's Avatar
Coolant Leak
Long story short.... I replaced my radiator cap due to seeing coolant residue down the side of the radiator starting at the cap. Prior to replacing the cap I never saw any coolant on the ground or anywhere other than the side of the radiator below the cap. AFTER replacing the cap filling and burping the system I drove the car a good 30 miles. Temp never went over 195*. Just went out and checked and now there is a small pool of coolant directly under the harmonic balancer on the ground.
God Bless Billiards!!!!
pocketmaster is offline
post #2 of 3 (permalink) Old 01-18-2015, 07:35 PM
One thing to consider is if you had a leaking cap it didn't build enough pressure to make the water pump leak.
post #3 of 3 (permalink) Old 01-18-2015, 07:55 PM Thread Starter
Basically the pump COULD have been bad for a while and fixing the cap means it wasnt masking the pump problem any more.....good point
coolant leak 06Goat88Rc Service, Maintenance and Technical Discussion 1 06-07-2013 10:06 AM
06 coolant leak offroadfury6 Engine Discussions 10 05-01-2013 01:30 PM
Coolant leak BatmanGTO 1964-1974 Tempest, Lemans & GTO General Discussion 36 09-21-2011 12:58 PM
Engine coolant leak DanielFinzel Engine Discussions 10 07-09-2010 07:17 AM
Coolant leak GTODAVE05 Service, Maintenance and Technical Discussion 18 11-21-2005 02:18 PM
