cylinder not firing - Pontiac GTO Forum
post #1 of 7 (permalink) Old 12-20-2010, 08:07 PM Thread Starter
IMCauley's Avatar
cylinder not firing
I've got an 05 gto that I think has a cylinder not firing all I know is as I was traveling down the highway the entire car began to shake as I shifted into 6th gear and the engine light began to blink, after coming to a stop it began to backfire after reving it high than 1900. Can anyone shed somme light? Give me any suggestions? Thanks!
IMCauley is offline
post #2 of 7 (permalink) Old 12-20-2010, 09:12 PM
Make teh secks on your OBDII port with a scanner and find out what's up. A blinking CEL ought to have stored a code.
Poncho Dan is offline
post #3 of 7 (permalink) Old 12-20-2010, 10:57 PM
GM4life's Avatar
Start simple and check your plugs and wires, and have it scanned by Autozone.
GM4life is offline
post #4 of 7 (permalink) Old 12-21-2010, 12:56 AM Thread Starter
IMCauley's Avatar
Sounds like a good idea. Do you have any other possible ideas what this might be? I'm just concerned because not only did it back fire on me every time i revved it higher than 1900 but as I was driving through the city to get to my garage it would act really jumpy and then kind of sluggish.
IMCauley is offline
post #5 of 7 (permalink) Old 12-21-2010, 01:41 AM
87GN06GTO07IRL's Avatar
If it's only one dead cylinder it's usually injector, plug, wire, or coil. Find out how many cylinders are missing and we'll go from there.
87GN06GTO07IRL is offline
post #6 of 7 (permalink) Old 01-02-2011, 10:33 PM Thread Starter
IMCauley's Avatar
Well all is good, I was able to bring it in to work and found it an embarrassingly easy fix...haha but thanks for all of your inputs!
IMCauley is offline
post #7 of 7 (permalink) Old 01-03-2011, 10:35 AM
6QTS11OZ's Avatar
Would you care to share what it was just in case it happens to someone else?
~I'm ya huckleberry~
~516rwhp/500rwtq~
6QTS11OZ is offline
Hmmm...cylinder 4? Cylinder order??? WanaGTO Service, Maintenance and Technical Discussion 3 07-15-2009 08:07 AM
Cylinder Heads JET 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 06-26-2009 09:19 AM
389 firing order? noluck 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-19-2009 06:08 PM
1972 lemans firing points nocturn2 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 05-04-2009 03:32 PM
1968 firing order HELP wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-19-2006 06:10 PM
