Daytime Running Lights - Pontiac GTO Forum
post #1 of 12 (permalink) Old 05-12-2005, 10:57 AM Thread Starter
The_Goat's Avatar
Anyone know of a way to disable the DRLs?
The_Goat is offline
post #2 of 12 (permalink) Old 05-12-2005, 11:34 AM
I believe that turning off the DRLs is an option if you get the instrument cluster reprogrammed.
Jim
FoMoGo is offline
post #3 of 12 (permalink) Old 05-12-2005, 11:35 AM
GTPprix's Avatar
You can pull the relay and it will kill the lights but you'll still have the annoying indicator. If you are interested, I can program them off AND the indicator as well as add a shift light/buzzer and some other options as seen here:
http://ls1gto.com/forums/showthread.php?t=16676
I'm also doing a group buy for this programming in Chicago in June if you are interested:
http://ls1gto.com/forums/showthread.php?t=25177
GTPprix is offline
post #4 of 12 (permalink) Old 05-12-2005, 03:38 PM
I removed the relay and ignore the indicator. I've been married a long time so I'm very good at ignoring things. I may be interested in the programing, though.
GTO-Quikls2 is offline
post #5 of 12 (permalink) Old 05-12-2005, 03:58 PM
GTODEALER is offline
post #6 of 12 (permalink) Old 05-12-2005, 04:56 PM
UTLawyer is offline
post #7 of 12 (permalink) Old 05-12-2005, 06:36 PM
What was that?
GumbyGoat is offline
post #8 of 12 (permalink) Old 05-12-2005, 07:21 PM
[IMG]http://www.tool-up********/tooldev/images/items/24496.jpg[/IMG]
Groucho is offline
post #9 of 12 (permalink) Old 05-12-2005, 07:47 PM
May I suggest the obvious....if thine bulb offend thee, pluck it out.
Wing_Nut is offline
post #10 of 12 (permalink) Old 05-13-2005, 08:44 AM
When in June and where in Chicago? Whats the cost?
I would like to make it as long as it isn't the 17th-19th of June
Afterglow is offline
