Daytime running lights and dash lights dont work!!!!! - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-20-2010, 02:08 PM Thread Starter
after my friend did his header installation his daytime running lights and the gauge lights dont work. he sent it to a mechanic and the mechanic fixed it but i week later they stopped working again. i know that there is a short somewhere but unsure where to start looking.
has anyone had this problem before?? how did u fix it ???
Vettekid1992 is offline
post #2 of 2 (permalink) Old 09-18-2010, 10:27 PM
I had a similar problem w/my lights. Check the back of the fuse box for corosion and use a check light w/ground to make sure you have power into the fuse box and out to the light sockets. Follow the wiring diagrm colors in the repair manual. That is what I did and after cleaning w/elec. cleaner spray and a small wire brush my problem was solved. Be sure to disc. the battery first. Good Luck.
wlbuckles is offline
DRL (Daytime Running Lights) bigmac 2004-2006 GTO General Discussion 54 09-05-2010 12:06 PM
best white Bulbs for the daytime running lights? joeyk97 Exterior Discussions 1 04-08-2007 09:44 PM
Daytime Running Lights oldgoat Interior Discussions 3 04-10-2006 10:58 PM
Daytime Running Lights The_Goat Service, Maintenance and Technical Discussion 11 05-13-2005 10:09 AM
Daytime Running Lights tparker Service, Maintenance and Technical Discussion 9 02-09-2005 10:24 AM
