Dead key - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-15-2015, 01:20 PM Thread Starter
Dead key
My spare key is completely dead and the key I use now only works right next to the door. I know that the key is soldered together and it is very expensive to get a new key and have it reprogrammed. So what is my best option?
yellowjacketgirl is offline
post #2 of 3 (permalink) Old 04-15-2015, 07:45 PM
The key fob case is glued together and the battery is soldered to the PC board inside. It is possible to slice a battery and carefully solder it in but it is easier to buy a new (must be new) fob and program it yourself. I got mine off eBay for about $50. I believe the self program can only be done if you have a working fob. I can dig up the instructions or you can search for them; it is along the lines of turning the ignition on, waiting approx 15 minutes for it to chirp, turn off then on, and repeat three times.
younggto is offline
post #3 of 3 (permalink) Old 04-16-2015, 09:46 AM
HP11's Avatar
Quoted: 24 Post(s)
If you are adept enough or know someone who is adept enough to take the fob apart and remove the battery and solder a new one in you could then put the circuit board and battery in the replacement case in the link below using your present key blade. These come apart easily and are held together with screws rather than glue for easier future disassembly. And they're only 10 bucks.
04-06 GTO Remote Key FOB Case Shell Uncut: GTOG8TA.COM - Late Model Pontiac Performance and Restoration Parts - Home
Here is a link to a how to on changing the battery. I also says where to get the replacement battery.
http://www.ls1gto.com/forums/showthr...99#post8411799
You can also get batteries that will work here:
http://www.ebay.com/itm/2-Batteries-...3D130914986510
HP11 is offline
Dead Battery Sailor's Cupcake Service, Maintenance and Technical Discussion 5 04-09-2012 11:46 PM
Not Dead injn37 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-05-2010 12:19 PM
Dead Pedal??? GTOMOE9 Engine Discussions 15 07-21-2010 04:28 PM
2 dead GT's darkfire00 Racing and Kill Forum 9 08-14-2007 08:09 PM
Dead Battery?!?! SJAndrew Service, Maintenance and Technical Discussion 4 06-29-2006 12:41 AM
