Dex-Cool Fears - Pontiac GTO Forum
post #1 of 9 (permalink) Old 01-04-2006, 09:19 PM Thread Starter
Dex-Cool Fears
Just purchased 04 GTO with 21K and have experienced 2 temp. spikes. I read all of the disasters with "Death-Cool" & would like any suggestions on possible coolant replacement that still satisfies warranty. I,m definitely not waiting til 5yrs. or 150K for replacing coolant. Bob
Bob L Musser is offline
post #2 of 9 (permalink) Old 01-04-2006, 11:02 PM
What you hear about dex cool?
adearmas2 is offline
post #3 of 9 (permalink) Old 01-05-2006, 06:18 AM
I've never liked Dex-Cool. I feel that it's partly to blame for the reason why I see so much premature gasket failures on v8 and 6 cyl engines...I've changed intake gaskets on v6's that were only about 2 years old. It even leaks past hose connections, clogs up radiator caps, etc...
I'll probably stick with it in my GTO, but I'll treat it like it needs to be flushed every two years instead of believing that it's a longlife coolant.
ModBoss2 is offline
post #4 of 9 (permalink) Old 01-05-2006, 09:51 AM
Your car is NOT getting hot. It needs the instrument panel either reprogramed or replaced (depends on VIN of car). There is a TSB for this repair! It has nothing to do with your dex-cool coolant.
VQ35DE is offline
post #5 of 9 (permalink) Old 01-05-2006, 11:24 AM
b_a_betterperson's Avatar
Agreed. Have your instrument cluster checked out. There's a software problem that causes the temp indicator to spike. If you just started you car after it has been sitting all night -- and you get a max temp indication within a minute or two -- that isn't a coolant problem.
b_a_betterperson is offline
post #6 of 9 (permalink) Old 01-05-2006, 11:37 AM
Make : PONTIAC Model : GTO Year : 2004
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Num : 050849003 Date of Bulletin: JAN 01, 2005
NHTSA Item Number: 10013486
Component: ENGINE AND ENGINE COOLING
Summary:
SPEEDOMETER ERRATIC MOVEMENT FUEL GAUGE DOES NOT GO TO FULL AFTER FILLING ENGINE COOLANT TEMPERATURE GAUGE READS HOT AND COOLANT TEMPERATURE LIGHT ILLUMINATES. *EH
05GTO is offline
post #7 of 9 (permalink) Old 01-05-2006, 12:17 PM
Summary:
You're all over these today Randy!
GTODEALER is offline
post #8 of 9 (permalink) Old 01-05-2006, 05:37 PM Thread Starter
Thanks, It was my fault in connecting the two items,(Dex-Cool & Temp spike). My Bad. I will call my dealer about instrument panel...........Bob
post #9 of 9 (permalink) Old 01-05-2006, 05:49 PM Thread Starter
I appreciate your sentiment, it really scared me when I came across Dex-Cool's recent history and the fact that GM is standing firm behind this product doesn't sit well with me. I did contact my long-time independant mechanic, Carolina Imports, Craig races corvettes and he has also heard of the horror stories but he uses Dex-Cool in his vette, but he added that he drains & breaks down his engine a lot more than the average street car so he suggested and, you might want to check this out also, to switch to Peak Global coolant which is designed for aluminum block engines. Anyway he said I should sleep better at nights.............Bob
