Dif Noise - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-24-2006, 10:23 PM Thread Starter
Dif Noise
Ok here goes...I have the dreaded whine...I have a great extendo warranty so the dealer can kiss my hairy white ass, don't gotta use em. Now my ASE shop and warranty say ok to replace with Pontiac parts. So if I replace with 3:91 gears and all new guts I should not have the whine come back right???
dgoat4me is offline
post #2 of 3 (permalink) Old 02-24-2006, 10:58 PM
Have you tryed just replacing the Diff fluid , sometimes that can help. I don't think you can get parts to replace the pinion bearing from Pontiac , that's why they are replacing the whole pumpkin. I want to say all replacement Diff parts also come from OZ. The gear ratio has nothing to do with the whine , if any gears are not set correctly they too will wear improperly and develop the dreaded whine. If you replace the complete Diff (say Kaaz) with 3.91's for $2000
then you may not have the Dana Whine , but from what I have read the Kaaz is not totally noise free - its just a much better LSD and 3.91's really add to SEG's. Hope that helps and Good Luck...
Xcommuter is offline
post #3 of 3 (permalink) Old 02-25-2006, 07:16 AM
PHOTOGOAT's Avatar
Also keep in mind that the diff is bolted to the chassis of the car, not hanging on springs. With a solid mount, some transition of noise is to be expected, just not too extreme.
2005 GTO
PBM, RI, A4 with 18" wheels
One of 68
78 Trans Am
46,000 miles, BBC 402
4 speed
Custom automotive photography services available.
PHOTOGOAT is offline
