Differential Drain Plug Size? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 04-16-2015, 08:31 PM Thread Starter
So im replacing the differential fluid soon (Torco SGO) and I wanted to do a tools check. Ive heard the fill plug is a 30MM socket. Anyone know what size the drain plug is? I suppose I could always use an adjustable wrench but I prefer not to...
Thanks!
Evan
evanpatchay is offline
post #2 of 6 (permalink) Old 04-16-2015, 10:08 PM
HP11's Avatar
Quoted: 24 Post(s)
The drain is a 15MM. 30MM for the fill is correct.
HP11 is offline
post #3 of 6 (permalink) Old 04-20-2015, 12:39 PM Thread Starter
Thanks!
post #4 of 6 (permalink) Old 04-20-2015, 06:16 PM
If you haven't done it yet loosen the fill before you remove the drain. It can be hard to loosen sometimes and you don't want to drain it until you know you can fill it
post #5 of 6 (permalink) Old 04-21-2015, 10:01 AM Thread Starter
Thank you, thats good advice!
post #6 of 6 (permalink) Old 04-27-2015, 04:25 PM Thread Starter
Update: I replaced the gear oil with Torco SGO (75-140 I believe) and type F friction modifier. Liking it a lot, things seem to be a lot quieter and I am glad to have a little more protection since there were very very fine metal filings in the old diff fluid.
Thanks for the help,
Evan
Oil pan drain plug? DaveP Member Introductions 2 10-26-2014 04:14 PM
Replaced plug/gasket, oil drain plug still leaky! KingJacobo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 10-21-2012 02:16 PM
Help Trans Drain plug leak SWGOAT Drive train, suspension, alignment and brakes. 3 03-09-2012 11:37 PM
Magnetic oil drain plug Cobra126 Service, Maintenance and Technical Discussion 3 10-14-2009 10:57 AM
Date coded plug wires and plug question 70gto 1964-1974 Tempest, Lemans & GTO General Discussion 7 09-26-2008 03:25 PM
