Differential Limited Slip Additive - Pontiac GTO Forum
post #1 of 8 (permalink) Old 03-19-2014, 04:58 PM Thread Starter
HI all, going to be changing out the fluid in the rear this coming weekend and was wondering if 1oz of this (K & W Chemical TRANS-X Posi-Trac Limited Slip Gear Oil Additive 402508: You?ve found the best Gear Oil at Advance Auto Parts) stuff would work. I helped my dad change out his in his truck just a week ago and he used 4oz of it, so I have some left and was wondering if it would work.
by the way, I was going to go with the Torco 85w-140 gear oil as it has been recommended everywhere online.
Rgrafton is offline
post #2 of 8 (permalink) Old 03-21-2014, 05:48 PM
Use the Torco "FM" type modifier. Yes it's a "Ford" type but remember this is an Australian car with a Dana diff and that's what it takes. I would not use that stuff you show there. The correct way to add it is to add about an ounce, drive for a little bit and do some slow very hard turns in both directions. If you hear popping add a little more and repeat. Do that until it no longer pops. With a diff that isn't brand new it may take a different amount than someone else. You want as little as needed to prevent pop. The modifier makes the oil slipperier so the cones slip properly. Too much will give you one wheel peel-out.
post #3 of 8 (permalink) Old 03-23-2014, 02:18 PM
Steamwalker's Avatar
Torco Type F additive.
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #4 of 8 (permalink) Old 03-25-2014, 11:59 AM
pocketmaster's Avatar
Is it true that you do not need FM if you use Royal Purple ??
God Bless Billiards!!!!
pocketmaster is offline
post #5 of 8 (permalink) Old 03-25-2014, 07:37 PM
If you are not going to use Torco, go OEM.
06/QSM/A4
SoCal Goat Club
post #6 of 8 (permalink) Old 04-09-2014, 03:03 PM
SIXO GTO's Avatar
Torco RGO 85-140 2 qts & 2 oz torco Type F additive & ALL is GOOD !
SIXO GTO is offline
post #7 of 8 (permalink) Old 05-23-2014, 12:29 AM
Don't use royal purple, been there done that wrong type of modifier. Put it in my rear end and after about 20 miles driven sounded like the rear end was falling apart. Go to ford and get their modifier that's what I did until my torco came in. Don't get any on ya either that stuff stinks!
stephen77375 is offline
post #8 of 8 (permalink) Old 05-23-2014, 12:31 AM
P.s. The K&W doesn't work either that was what I tried first before royal purple.
Limited slip FlambeauHO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 20 03-22-2012 09:08 AM
limited slip problems? Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 07-07-2011 08:22 PM
Limited Slip and No Slip Differentials....Whats the difference? xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 06-16-2011 07:18 AM
limited slip diff. vanillagorila Drive train, suspension, alignment and brakes. 0 09-12-2006 05:57 PM
