Does the change oil reset procedure reset anytime it's done? - Pontiac GTO Forum
post #1 of 9 (permalink) Old 02-23-2011, 10:25 AM Thread Starter
In other words does the "change oil" indicator need to be activated for the pedal action to work?
I'm asking since my car is at 98300 miles and I like to change the oil at 100k with all the other fluids and just start from a round number.
I changed the oil at 97k~ and did the pedal reset procedure.
My Youtube Channel
Supercharged (Roots) 6.0 GTO
Supercharged (Twin Screw) 3.0 NSX
Supercharged (Centrifugal) 4.3 S-10
batmans is offline
post #2 of 9 (permalink) Old 02-23-2011, 11:33 AM
jpalamar's Avatar
You need to manually tell it you changed the oil. It will not automatically reset. There is a stick how-to.
jpalamar is offline
post #3 of 9 (permalink) Old 02-23-2011, 11:43 AM
If you want everything to round to 100K, you'll need to change the oil at 100K and reset the engine oil light notification.
Typically you won't get the change oil message for about 7K or more miles since the computer bases the oil life on the revolutions of the motor and not miles driven. You'll have everything reset at 100K for a short time until the oil sensor goes off roughly at 107K miles or so.
post #4 of 9 (permalink) Old 02-23-2011, 11:57 AM Thread Starter
So if the oil change light/message hasn't popped up and I do the gas pedal depression procedure while the engine is off then will it zero out from that point?
My Youtube Channel
batmans is offline
post #5 of 9 (permalink) Old 02-23-2011, 01:02 PM
jpalamar's Avatar
You got it.
jpalamar is offline
post #6 of 9 (permalink) Old 02-23-2011, 01:31 PM
It does, but you don't know if it actually did and there is no way to check.
LS2 MN6 is offline
post #7 of 9 (permalink) Old 02-24-2011, 11:35 AM Thread Starter
Good point. I'll keep a mental note and check at 7k~ miles after the reset has been done.
My Youtube Channel
batmans is offline
post #8 of 9 (permalink) Old 02-24-2011, 12:46 PM
You know when it worked when the light goes out.
Doing it blindly.... repeat the procedure a few times in succession as a justin case.
post #9 of 9 (permalink) Old 02-24-2011, 04:01 PM
GTOAA 04-06 Technical Advisor
GTOJer's Avatar
Good idea.
Jerry
GTOAA '04-'06 Technical Advisor
My Shop
KPE - Klaus Performance Engineering
2004 Pontiac GTO 6.7/M6/Barbados Blue (1 of 271) My Car Page
Featured in the April 2007 High Performance Pontiac Magazine
GTOJer is offline
Oil Change Reset Function - HELP! XV Scott Service, Maintenance and Technical Discussion 15 10-11-2011 10:49 PM
Trying to Reset the Engine Oil Life System PatrickNJ 2004-2006 GTO General Discussion 4 08-28-2006 08:25 PM
How to Reset the Engine Oil Life System XGTO Service, Maintenance and Technical Discussion 3 04-28-2006 10:22 AM
Oil System Reset michaelskier 2004-2006 GTO General Discussion 2 03-24-2006 10:30 AM
Oil life light reset PWR_SHIFT Service, Maintenance and Technical Discussion 10 01-01-2006 01:04 PM
