donuts= broken goat? - Pontiac GTO Forum
post #1 of 8 (permalink) Old 06-24-2008, 07:47 PM Thread Starter
yeah... i admit it, i was doing some donuts in a parking lot. couldn't resist.
anyways, after i drove away it felt like my power steering was broken, as if the car was off that was how difficult it was to drive.
the car also whines (think supercharger) when you turn the wheel more than 45 degrees to either side. The whine has nothing to do with car speed and all to do with engine rpm (higher rpm= louder whine/higher pitch?
after i did this i looked under the hood and it looked like my steering fluid exploded. the cap was still on but there was fluid in the general vicinity ie. intake.
so i feel like a big dumb idiot, but will someone help me figure out what is wrong?
btw my car is a 2005 m6
greased is offline
post #2 of 8 (permalink) Old 06-24-2008, 07:59 PM
GM4life's Avatar
Check all your hoses and connection points. Then refill your power steering with ATF to proper levels after doing that turn your sterring wheel lock to lock many times to bleed the system. See what that does, first clean up the area to check for leaks. If that does nothing take it to the dealer admit to nothing.
GM4life is offline
post #3 of 8 (permalink) Old 06-24-2008, 08:03 PM Thread Starter
ok, any ideas on what the high pitch whining thing is?
greased is offline
post #4 of 8 (permalink) Old 06-24-2008, 08:10 PM
GM4life's Avatar
If the sound changes when turing the steering wheel it is your power steering pump. Most of the time when they make noises is when you are low on fluid or they are shot.
GM4life is offline
post #5 of 8 (permalink) Old 06-25-2008, 03:15 AM
or it's a ford!
koman is offline
post #6 of 8 (permalink) Old 06-25-2008, 09:01 AM
GM4life's Avatar
Originally Posted by koman View Post
or it's a ford!
So true.
GM4life is offline
post #7 of 8 (permalink) Old 07-03-2008, 01:54 PM
mr.gto's Avatar
i second that^^^^ a ford off the assembly line
Feel the torque
mr.gto is offline
post #8 of 8 (permalink) Old 07-25-2008, 05:55 AM
I second the low fluid levels in the power steering. You probably busted a hose somewhere (I did it a few weeks ago) and your fluid left. When your levels get low, you'll hear that whining sound.
I just disconnected my power steering. It drives fine so long as you make sure you're moving when you want to turn.
Nizidramanii'yt is offline
Goat Sightings and other misc B.S. PAULCAPASSO 2004-2006 GTO General Discussion 1 06-15-2008 03:57 PM
Took the goat out of Barn Today! NJG8GT 2004-2006 GTO General Discussion 5 02-03-2008 09:52 AM
Took the goat out of the barn for first time since Mid October!!! NJG8GT 2004-2006 GTO General Discussion 4 12-20-2007 10:05 PM
Goat in winter-hopefully no wear and tear?? joeyk97 2004-2006 GTO General Discussion 7 02-18-2007 07:38 PM
06 goat vs 72 goat tap goat Racing and Kill Forum 0 07-01-2006 05:48 PM
