Door lock retainers - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-17-2013, 08:30 AM Thread Starter
Quoted: 6 Post(s)
Door lock retainers
When removing the door panels, alldata states you have to replace the door lock retainers(RED). How do you pop them out? I assume they get destroyed doing so.
johnfin is offline
post #2 of 4 (permalink) Old 06-22-2013, 06:30 PM
mbergin's Avatar
Quoted: 9 Post(s)
If your talking about the clips that hold the lever to the lock cylinder and they're original, they will probably get destroyed. I pulled my door locks and although I tried to save them, its close to impossible. I bought a lock set from Ames and it came with new clips.
If your talking about the clips that hold the lock cylinder to the door, you just need to give them a good pull and they will come loose (spring clips). They can be re-used but I changed mine out.
Good luck!
Sent from AutoGuide.com App
mbergin is offline
post #3 of 4 (permalink) Old 06-24-2013, 07:27 AM Thread Starter
Quoted: 6 Post(s)
Clips
I am talking about the red clips that hold the plunger on. How do you get those out?
johnfin is offline
post #4 of 4 (permalink) Old 06-29-2013, 10:37 PM
Small flat head and they just pop out. They shouldnt remove 100% but mine did sadly as well as sadly mine were only good once.
Unknown1 is offline
Drivers door lock Papa Rad Service, Maintenance and Technical Discussion 7 05-18-2019 11:50 AM
Door lock delay johni53 Service, Maintenance and Technical Discussion 1 12-17-2012 12:37 PM
05 Door LOCK ISSUES FD Prez Service, Maintenance and Technical Discussion 7 02-21-2009 09:47 PM
64 Door Lock Replacement Koppster 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 2 02-11-2009 07:38 PM
Door Lock SpunkyRacer Service, Maintenance and Technical Discussion 5 03-30-2005 02:25 PM
