Door locks/Alarm/Stereo - Pontiac GTO Forum
post #1 of 18 (permalink) Old 07-23-2006, 07:53 PM Thread Starter
Sorry if this is a redundant thread, I'm just trying to figure this car out...
#1: Why can't I lock the doors using the console switch OR the lock knob if the driver's door is open? I pulled in the garage, locked the car with the keyless, came in the house, realized I forgot something in the car, unlocked the door with the remote from inside the house, then couldn't lock the doors with the button on the console or by physically pressing the doorlock knob down. Had to walk back to the other end of the house to retrieve the remote so I could lock the doors. What gives with this?? Why even put door lock switch in the car if it only works when you are inside the car and all the doors are closed? Is the only way you can lock the car from outside is with the remote?? Maybe I might need to lock my doors sometime but don't happen to have the remote with me, or maybe the battery in the remote died. Is there a way to override this feature? Seems really ignorant to me.
#2: Car was in the garage this morning, and I wanted to drive it to work. I always keep the car locked even in the garage, and for some reason I thought I would try the key to unlock the door instead of the remote. WRONG!! When I unlocked it with it's own key, it set the alarm off on the car, scared the heck out of me, and woke the family and 1/2 the neighborhood up at 5:30am. Took me several seconds to figure out how to shut the blasted thing off. Then the display said something like "alarm activated from driver's door". Why does the alarm go off when I unlock the car with it's own friggin' key? This seems really stupid to me... Heaven forbid you ever want to lock or unlock the car without the remote, whadya do, call a tow truck?
#3: This Blaupunkt stereo really sucks. The factory radio/cd in my Z-71 sounds 10 times better to my ears. I've fiddled with the amp settings, EQ settings, manual EQ settings, balance and fade, and it sounds like crap regardless what I do. It's either muddy and bassy or tinny. No happy medium that I can find. Cd's are crystal clear but still sound like crap. Not to mention the volume knob is on the wrong side of the stereo (obviously a throwback to the car's right-hand-drive origins), and I find myself grabbing the left a/c fan knob out of habit, thinking it's the volume... Any suggestions on a good replacement that will fit in the factory location, look correct, work with the steering wheel controls, and actually sound good?
KB
kegbelly is offline
post #2 of 18 (permalink) Old 07-23-2006, 08:02 PM
Premium Member
EEZ GOAT's Avatar
Send a message via Yahoo to EEZ GOAT
EEZ GOAT is offline
post #3 of 18 (permalink) Old 07-23-2006, 08:04 PM
Premium Member
EEZ GOAT's Avatar
question 2. welcome to that club. there is no way around it.
question 3 we all think it sucks.
EEZ GOAT is offline
post #4 of 18 (permalink) Old 07-23-2006, 08:05 PM
BV GTO's Avatar
Might try this procedure from another forum:
http://www.ls2gto.com/forums/showthread.php?t=17659
Stereo sounds good to me but my hearing had been damaged from loud rock long ago.
BV GTO is offline
post #5 of 18 (permalink) Old 07-23-2006, 08:32 PM Thread Starter
Originally Posted by EEZ GOAT
do you have 05 or 06?
Sorry, I should have clarified that. '06 M6.
KB
kegbelly is offline
post #6 of 18 (permalink) Old 07-23-2006, 08:37 PM
Premium Member
EEZ GOAT's Avatar
KB
got ya. i dont have an 06 with the door lock but
EEZ GOAT is offline
post #7 of 18 (permalink) Old 07-23-2006, 10:35 PM
wahts betta and m6 or an ls2 which is faster
06GeeTeeOOH is offline
post #8 of 18 (permalink) Old 07-23-2006, 10:51 PM
Is this a trick question? I have a M6 LS2...so she's no faster than herself. I'm the weakest link.
I'm assuming you meant what's faster a M6 or A4...and that is a debate that will go on forever here. They are so close in stats (as far as I've read) it comes down to drivers. In my case, I'm quite certain that most competent A4 drivers will beat me in the quarter because I'm old and slow. Give me a GMM rip shifter and a six-pack of Red Bull, and we might just have a race
ShoddyHog is offline
post #9 of 18 (permalink) Old 07-24-2006, 07:20 AM Thread Starter
Thanks for the tip. I tried what he said, but I coudn't tell much difference. I had already turned the EQ off and adjusted my bass and treble manually, but still can't get a mix I'm happy with.
kegbelly is offline
post #10 of 18 (permalink) Old 07-24-2006, 07:36 AM
try turning the amp up to 3/4 power level and then put Bass on +2 or +3 and treble on +5 or +6...that may sound pretty good.
I'm planning on getting a separate 200 or so watt amp to power the car's speakers and then trying to reroute the factory amp so that it is just responsible for the factory subs.
BostonF4$ is offline
